Hibnecker1
Everything posted by Hibnecker1
  1. i used a sawsall to get them trimmed down then a sanding drum on a drill to smooth them out and finished with a buffing wheel... looked good till i got new plastics
  2. The one i put on mine is awesome! its strong and easy to take off plus it makes a nice little foot bar for those times when you lie over the handle bars... I recomend it to everyone
  3. I keep putting money into this thing... just wish i could take it for a ride once in a while!
  4. I keep putting money into this thing... just wish i could take it for a ride once in a while!
  5. I like my Holeshot HD's!
  6. This stuff is tough! its a little hard to clean and actually has to be scrubbed to get like new again but I would still do it again... First week I had it, I slid down a bank and had to scrape the driver side against a tree and this stuff didn't even scuff! Its impressive as long as its preped well... o and go a few extra cotes on the floor boards like i did!
  7. The Suzuki Samurai project that I'm working on... started stock and bed linered the whole thing, 6" lift, 31x11.5 super swamper ltb tires and 6.5:1 low range transfer case kit so far. A Lot more to come!
  8. The 06 Duramax 2500Hd I just picked up... It won't be stock for long
  9. It is in Devil's playground. Go to the map and jump to the furthest upper left blue marker. Its labeled bonus vehicle. Or just drive to the top of the map and find the passage in between the two halves of the map. There is a small trail that turns off of the passage and you will see a truck with trailer and a purple and yellow banshee. press y to switch to it.
  10. It's finally done! How i missed the power!
    1. CFH87
      CFH87
      What did you do to your buiild
    2. volcrano
      volcrano
      i say that after every winter lol.
  11. I use klotz r-50 mixed 40:1 along with cherry gas scent and havent had a problem... it smells great!
  12. No air box on mine... like said above the oil is key!
  13. Trinity stage five? It must be a new line from Trinity
  14. I have never ran a uni but have never had a problem with dirt and i ride everything from dusty to muddy trails... I have dual k&n's with outerwears and klotz filter oil.
  15. What drives us to spend so much $ on a machine? Y do we use every hard earned dollar on a material item? ha ha
    1. CFH87
      CFH87
      because its like crack to a crack head...
  16. When mine wentit started puffing out the right pipe a bit then ten min later fell flat on its face with no power
  17. x2 fat man has to fly
  18. x2 lower a tooth on the front sprocket or go with smaller rear tires
  19. No complaints about my lsr +2's... and mine were powder coated but are now bed liner coverd to protect from grass and dirt rubbing powder coat off
  20. hate the terrible design of army vehicles
  21. Do a compression test and make sure your compression is close to the same... around 5 psi difference is good. I would assume it is prob. a carb problem though
  22. i like my ims. just an opinion but i didnt like the huge hump of the clark
  23. X4 my ebay oversize radiator and ims 5.6 gal fit like a glove
