98 banshee trinity 400 top end kit 68mm pistons rocket R2 pipes 35mm keihn flat slide carbs 250r style reeds power valves elka shocks +2 swing arm +2 a arms +2 steering stem race cut fenders oversize tank and lots of billet!
i used a sawsall to get them trimmed down then a sanding drum on a drill to smooth them out and finished with a buffing wheel... looked good till i got new plastics
The one i put on mine is awesome! its strong and easy to take off plus it makes a nice little foot bar for those times when you lie over the handle bars... I recomend it to everyone
This stuff is tough! its a little hard to clean and actually has to be scrubbed to get like new again but I would still do it again... First week I had it, I slid down a bank and had to scrape the driver side against a tree and this stuff didn't even scuff! Its impressive as long as its preped well... o and go a few extra cotes on the floor boards like i did!
The Suzuki Samurai project that I'm working on... started stock and bed linered the whole thing, 6" lift, 31x11.5 super swamper ltb tires and 6.5:1 low range transfer case kit so far. A Lot more to come!
It is in Devil's playground. Go to the map and jump to the furthest upper left blue marker. Its labeled bonus vehicle. Or just drive to the top of the map and find the passage in between the two halves of the map. There is a small trail that turns off of the passage and you will see a truck with trailer and a purple and yellow banshee. press y to switch to it.
I have never ran a uni but have never had a problem with dirt and i ride everything from dusty to muddy trails... I have dual k&n's with outerwears and klotz filter oil.
