sprinklerman
    38
Everything posted by sprinklerman
  1. i have one . PM sent
  2. gas tank, all reeds and cages and intakes sold. Shipped today, tracking provided. Threw in a pair of intakes for free if you can use them. If not pass'm on to someone who does! thanks. Airboxes, complete carbs, jets, airbox adapter, spindles, brake hub,and sproket hubs still available.
  3. nice run for a pump gas motor colby! Is that the motor your 24x12x10 14paddles are on? haha
  4. Mull has a billet gear. look them up in the sponsor section.
  5. bump. would consider some trading for handlebars, 39mm UPP intakes, or 12-14 pdl SLS haulers . i know some of those trades will invilve cash in one direction or the other. Thansk
  6. True. Obviously there is no "cure",,and a buyer/sellers BEST solution is to only deal with those whom they know to be trusted. But i see no harm in mandatory pictures to weed out the laziest of the dishonest sellers.
  7. No way to police this,,that's true. But i also feel that at least a large percentage of the deliberate scammer/ dishonest sellers would be discouraged from pawning their junk off on people if pictures were mandatory. It wont solve the problem but it sure wouldn't hurt.
  8. i agree with posting pix. Sometimes my time is limited,so i have to post the pix the next day,,,but i always try to get them IN THE AD..i hate that "txt for pix" lazy stuff. Why not make pictures in the ad mandatory? Maybe that will help dissuade scammers/deadbeats .
  9. also, the carbs DO include a nearly new Motion Pro cable and of course TORs delete,
  10. all threads and studs are good. Just the trenching costs 150.00 , so you are getting the cases for 50.00. Even whacked cases go for more than 50.00. haha make offers,thx!
  11. I also will throw in the ported cages with the boysen dual stage reeds. they are 3 months old. I believe the carbon fiber reeds in pix are carbon techs,,cant remember tho. Gas tank 30.00 (includes petcock and gas cap. I will also throw in the unmodded airbox if you buy the modded one with K&N and proflo. (prices above) Also have a 2nd "pro Flo" adapter ( UMI brand) 15.00 Carbs JUST came off bike. Bike runs REAL good. Ran them at last BHQ ride on 4mm stock cyl. Also have 2 sets of GOOD spindles ( 30 per set) 2 rear sprocket hubs (15.00 each) 1 rear Brake Hub ( 15.00)
  12. Pearl white has always been in my top 3 favorite colors. I just wonder how it will hold up and look in an ATV environment ?
  13. i used to use that expensive cable lube , but switched to the Liquid Wrench brand cable and chain lube and like it better,plus you can get it at any auto parts store and the can is much bigger, get a lot more for your money.
  14. ASV without a doubt. had both. Very important to PROPERLY LUBE your cable..
  15. i have a set for 40.00. they are nice. can get you pix if you are interested.
  16. they are the boysen dual stages. im pretty sure that i have a set of carbon techs on cages that id throw in on the deal if someone buys it all. The airbox is cut along the sides and bottom for max airflow and easy removal. The front and rear mounts are still intact tho. The boots are included as well. Pictures in a few.
  17. ^^^^ ive used Pro X several times with no problems,but as fouled said, the bore has to be to spec. Prefer the idea of a pitson that swells in the bore less( cast Pro-X),,but since all i have are cubs now,Wiseco it is. No problems with them either. ( unless it was something i did wrong,haha)
  18. it really sounds like they are setup for alky...but im not an expert on it. i ran it about 14-15 yr ago. and am going back to it next season. But from what you're describing,thats what you have. The PJets are for alky,also the pulse line. If the dump tubes are drilled for alky , then its going to be waaay rich for gas. What you have to do now,is take the carbs off and measure the dumptubes and see what jets and needles are in it. Get some numbered drill bits and see which one fits in the dumptube,thatll tell you the size.
  19. I have some stock carbs in excellent shape,with complete set of main jets (200somethings- 380's) <75.00> Stock ported reedcages with boysen reeds <40.00> BRAND NEW never ran,factory intakes (cut wings for V-3's but will work on stock intakes) < $30.00> Stock/modded airbox with K&N filter ,with outerwear, Pro design billet adapter < $ 50.00> Will post pictures tomorrow. Thanks!
