Soliciting advice. I've read many posts and I consider myself "fairly" savvy with these things, but I can't figure it out.
I just bought a 99% stock '97 from the original owner (60 y/o gentleman). The only mod I see is a K&N air cleaner in a pro design box. When I looked at the quad it fired on the first kick cold (I felt the jugs and pipe to be sure). Idled excellent but didn't rev up, just bogged. We pulled the carbs and ensured the floats were not sunk or stuck. Everything was in order and all jets were clear. The little tube between the carb chokes was in tact as well. So I bought it at a great price thinking it was TORS related and an easy fix. Got it home and disconnected the plugs from the TORS caps, removed the TORS brain, and disconnected the throttle switch. Didn't fire after that. Plugs are wet. Getting spark when I touch them to the head. Compression is 110 on both cylinders. Pulled the reed valves and they look great.
Not sure what to check next. I'm going to put fresh fuel in tomorrow for good measure. The wiring harness is virgin and not hacked anywhere I can see. What are the odds that a stock, well maintained bike would shear the key on the flywheel and throw the timing off? Haven't pulled that cover yet. I do not have an ohmmeter to check spark strength yet, but considering a purchase in my near future. Any other advice on something obvious I might be missing?
