bansman76
Everything posted by bansman76
  1. got a caliper. still need a flywheel ,
  2. nobody have any ?
  3. in need of a good flywheel , and rear caliper.
  4. the harness is brand new oem one..i don't have a yellow/red wire coming out of the harness . this is a new build bike so I don't have everything hooked up or all the parts I need just yet, but I am getting close to be able to have it running..
  5. according to the manual I should have a green, a yellow and a black for the tail/brakelight. coming out of harness by the cdi box. I have a solid yellow, solid blue, and a black . I also have a BLUE wire coming out of harness about 3 inches back from where the stator connector is. the wire coming out of regulator is also blue. so im not sure what wire to hook the reg wire into ? I have a 93 shee sittin here to look at but it doesn't do me any good cuz it just has a tail light..
  6. so plug my voltage reg into the yellow/red wire ? and the blue wire that comes out of harness by the stator plug is for the rear lights too ?
  7. hey guys. I bought I new harness for a 03 up. upon trying to connect all the wiring, I found a blue wire coming out of the harness about 3 inches back from where the stator connector is. im trying to figure out if this is the voltage regulator wire or not ? I also have a blue wire comin out by the cdi connector along with a black and yellow wire. according to the Clymer I should have a green yellow and black for the tail/brake light. any help is appreciated !!
  8. cool. thats what i was thinking but wanted to make sure.. thanks savage..
  9. my throttle housing dont have the wires coming out of it. so just silicone it up ? what should i do with parking brake wires ?
  10. do the wires for the parking brake switch need to be hooked up if i have no parking brake ? and what about the wires coming out of throttle housing ? . thanks
  11. will you be making some for stock swingarms/carriers ?
  12. pm returned
  13. bump bump.. still need wiring harness, front aftermarket shocks, flywheel, good clutch basket ( with hardware )
  14. sealed the keyway and resealed my intakes and all is good..motor going in frame tomorrow...thanks for the help guys
  15. ok guys ill try that when i get home from work. thanks p.s. im using my little slime compressor not my big compressor lol
  16. well i finally got my motor built over the wknd. put leakdown tester on it tonight and will build pressure but as soon as i turn compressor off the air leaks right back out around the keyway on the crank( clutch side ) . i need some ideas on what to do next please..
  17. thanks for the advice guys
  18. i have a hjr mx hardcore port on stock stroke hot rods crank . .40 cylinders with chariot cages boyseen reeds, pc pipes,+4 timing.. just curious if it would help or hurt my motor
  19. im wondering whats the advantages and disadvantages are of these before i buy one ? thanks
  20. yea i googled it and found that out.lol thanks
  21. i want one will pm info
  22. hey guys..this is probably a stupid question but ive never dealt with any aftermarket heads.. i bought a noss head with my build from kevin.. got the head on but need to know whether the o ring goes on first then the copper washer then the nut ? or the copper washer then o ring then nut ? thanks ..
  23. hell see if your brother would make a couple more.. i would buy one if it was reasonably priced
