bansman76
Everything posted by bansman76
  1. that looks sweet too buckwheat . could run airbox with no issues then
  2. ive been all over brimstone. some damn good trail riding there, trails end which is right there too has some good riding on the TWRA trails too.. plan on going back for the white knuckle event memorial weekend .
  3. If ya turn battery box around the rear plastic will cover battery up. But looking at mine, if I turn it around I would have to cut some of Plastic to be able to get to battery and would have to at least cut the resovoir tank bracket off the back of air box. Looks like could be doable for wet or muddy trails Sent from my iPhone using Tapatalk
  4. I hadn't thought of that Willa Ill look into that too
  5. Will do when I get home tonight
  6. It might be overkill but I had jd build me a box for a ltr 450 battery seeing as I had one sittin on shelf lol
  7. Cool. I was thinking I'd be alright but wanted couple other opinions Thanks guys
  8. Yea 21cc domes.
  9. Hey guys. Checked my compression today and got 150 psi. Done it 3 times each cylinder got same number every time. Is this still safe for 93 octane pump gas ?
  10. agree please do tell lol
  11. not seeing them on their website that's why I asked
  12. what size ?
  13. are the ac's like these ^^^ made anymore ?
  14. I got .042 on squish test. Motor runs good.
  15. This time I just went to 20 ft lbs.
  16. Will pick up some solder tomo and check it
  17. well after new intakes gaskets, water plugs,base gaskets, cylinders decked, a tube of 1211, and new Orings performed leakdown.. lost 1/2 a pound of psi in 30 mins .. believe im good now.. thanks for all advice
  18. What cc domes ?
  19. Yea I wish I hadve now. I'm hoping with new base gaskets , water plugs, cylinders decked , and new Orings that it seals up.
  20. Yea I drained them b4.
  21. Plug on left cylinder was leaking yea. Coolant was on right side of crank
  22. ive got all the coolant out of the area. im curious to know how it can get past piston rings or how it go to the crank area
  23. another question on this guys while im waiting for cylinders to get done... if the transfers aren't leaking then how else could coolant get in to crank area ? ??
  24. No leakage into transfers but did find that rubber plug on bottom of left cylinder leaks. Will be ordering them tomo !! Cylinders going to shop to be decked tomorrow.
  25. Will do. Ty for advice
