coryv4
Everything posted by coryv4
  1. is ur pickup coil rubbing the flywheel? r you sure its comeing from the engine and not the chain roller? i had a worn out roller and i thought i fucked up my tranny cuz i heard a weird grinding noise but it was just the chain sliding off the roller
  2. i break mine in by starting it let it idle for 5 mins blip the throttle acouple times then kill it repeat again then the 3rd time i take it around my field quarter throttle 3rd gear then the final time i shift through all the gears 3/4 throttle then its ready to go i always let the cyls get cold to the touch inbetween heat cycles
  3. i run pcs on my 421 serval great pipe for trail and play riding but it is a pretty much a mid range pipe pulls like a mofo mid range then smooths out on the top end
  4. through m&m the 421 kit (68mm cub cylinders,4mil crank,head, domes, and pistons) was $1700 then with small stuff like billet basket new clutches lock out lockout cover and dunable override i have $2500 into it
  5. yeh but those are pretty scuffed up id give him 200 max
  6. chech the choke tube inbetween the to carbs
  7. dont buy from a dealer you will always over pay you could better for less
  8. so does that mean i can port the cylinder on a yfz 450?....Just kiding
  9. where are you located?
  10. also i had the exact same prob with my 1-5 it would shift fine every couple pass but then i found out you need to have your shifter perfectly adjusted or it will not shift right
  11. i dont really think you should be putting plastic in a 400 degree oven but that my 02
  12. i hear that all the time people say ported head and then i have to think to myself how the hell do you port a head on a 2 stroke
  13. are they silenced?
  14. makes since now
  15. my ricky had the same thing 2 yellows and a black no idea why
  16. how do you have a ported head on a 2 stroke?
  17. nothing to do with ur q but why long rod on stock stroke?
  18. yeh no shit if he wants some good lower pipes ill trade him my pcs ill even pay for shipping both ways
  19. ur compression is low 19cc domes might be time for new rings
  20. then you prolly just need new rings pull the head off and check piston to cylinder clearence and make sure ur cylinder isnt scored up
  21. kick it a good 20-30 times per cylinder only way to do it just to make sure and 100 psi seems pretty low
  22. that is correct i built it clutches were slipping and somhow notched the fuck out of my basket put a lock up and billet basket in works great
  23. i meant half throttle has in mid way throught he rpm range
