no, you have to split cases and remove crank putt seals on and drop it back in boom you are doneseal it with some durabond and slap it back together. i would replace all seals while you have it all apart
have you checked the wireing harness with a contenuity tester might have a nick in it. and why do you have cpi inframes on a stock cylinder jugs doesnt make sence to me.
my friend has the 525 outlaw and i have 20 over super stock pistons and a jet kit and a open air box and i will beat him if he gets the jump we will run side by side until 6th gear then i pull alittle on him they are very torque bikes on the low end not the top end you will win keep us posted.
you let it warm up then shut it down and let it cool of then ride it around a little bit no more than 1/8th throttle then let it cool down next time ride it alittle harder so on and so on 10 hours later change your oil and look for magnetic metal .
first thing first you fucked it up go to the doctor.second don't hit the eject button unless you really reaaly have to only if you are going to get hurt.
