toytech
Everything posted by toytech
  1. thanks for the info I will look at the cpi pipes
  2. thats what I have they made quite a bit of difference, very good suggestion!
  3. they are what I got when it was almost stock, what do you recomend? we have to run spark arrestors in michigan, Jeff at FAST said when I have him do an agressive dune port to use the toomey t5s are those good
  4. it's a 4 mill, stock cyl 40 over, vforce reeds,intake with built in crossover,35 mm round slide mikuni carbs,cool head with domes cut for the 4 mill crank,fmf fatty pipes with turbine core silencers, with ports cleaned up and matched, 8 inche pod filters.
  5. I would go with wiseco specs and break it in correctly! and make sure the shop chamfers the ports correctly. I send all my 2 stroke cyls to the guys that do them only so they will last longer
  6. yes you will get covered!!! but worth it not looking at them elephant ears.
  7. 117 psi compression is not very much
  8. so I should definetly buy the haulers? Is the best size for a shee 22 x10 x 8 ? thanks for the info guys! I will definetly hookup a lot better in the sand with the edge 10 paddles than with my gecko's
  9. scat trak edge tires how do they compare to the hauler tires? I borrowed a set for this weekend to try
  10. 4 of us will be there on the 15th and 16th to ride and watch the hillclimb, 2 banshees,1 ltz 400, 1yfz 450
  11. yeah this site and the sponsors are awsome thanks to all who contribute
  12. thanks thats what I wanted to know, who has the good stuff?
  13. timeserts have a lip on top and the threads are cut with a slight taper at the bottom the insert tool opens it up and locks it in, they will not back out. if it wasn't for timeserts cadilacs would need new blocks when you do head gaskets, they haved saved GM alot off money!! I just saved a customer about 2500 bucks by putting them in the sparkplug holes that he blew plugs out of with 30 psi turbo boost and they are holding great
  14. has anyone used the clear hose from lowes without the braid inside, on their banshee yet do you think it will hold up ?
  15. Quad rules For M.S.B.A. Hill climb events 1. All QUADS must be in good working order no broken parts or broken plastic coming off. 2. Any cracked Plastic that’s about to come off must be repaired before the event. 3. All lug nuts must be tight and the center hub nut must have a cotter pin. 4. No leaky fuel tanks or fuel hoses. 5. The exhaust system must have a spark arrester that is state forest approved. 6. You must an approved Snell helmet with goggles. 7. Long sleeve shirt and long pants are mandatory no exception. 8. All Quads will be put into there class accordingly to motor size and stock to modified. 9. All Quads must have a working tether to run an M.S.B.A. event. 10. Moto- Cross boots are recommended. 11. Any Quad running nitrous must have the bottle secured to the frame of the quad, the hold down clamps for the bottle are to be bolted down to the frame. *NOTE (no wire ties or wire holding down the Nitrous bottle) 12. When running your quad up the Hill and you don’t make it to the top and you get stuck stay on the quad and M.S.B.A. official will help you turn the quad around DO NOT get off your quad for safety reason. I found this but I couldn't find if we need to be members or not or total entry cost
  16. I don't think I would want a used one for that it might taste funny
  17. time serts are not the same as heli coils they are ten times better!
  18. sounds like a deal to me I'd buy it
  19. yeah they are the only way to go, I use them when ever I have stripped threads
  20. do the spark arrestors have to have the usf stamp on them to be legal in michigan?
  21. All the MX guys around hear use the Elka's they love them, to rich for me I have works shocks with reses and love them they are 8 years old and still work great with no leaks and much cheaper
  22. a company called time serts makes the perfect fix for stripped threads look them up
  23. if compression is over 150 wich it should be, no anything over that needs race fuel
  24. I would like to thank Loco for a great web site!!!! and all the guys on here that help others in need. I have only ben a member for a short time and have had a lot of help and the sponcers are great people to deal with
  25. he hooked me up, and is very helpful, he spent 45 min on the phone after hrs to answer all of my questions and take my order great guy to deal with thanks Jeff !
