Hi guys, new member/owner of a 89-90 banshee.
So far i've had quite a bit of fun on this thing spent last weekend riding and playing in the mud.. Anyways i've got some questions / comments after playing around with it and was hoping someone here would be inclined to share some insight or advice!
See picture(s) for hopefully clarification on anything I refer to.
1) Tires - the tires that are on this bike don't do well in snow/ice at all.. Spin spin spin, where as my sisters 300ex goes pretty good with its stock tires.. Im pretty sure it's just the tires. Anyways we don't get a ton of snow here in central NC but I would like a tire that is good for trail riding and crossing streams/mud holes.
2) Carbs to Air Box.. There was a gap between where the carbs stop and the air box starts, which I assume there should be something here to make the transition.. For riding purposes since it was muddy I fashioned this out of some rubber material.. There also is no air cleaner inside the box under the seat recommendations on a good one would be appreciated.
3) Plastics - the plastics are white with the frame of the bike red, I think i've decided to paint these as they're not the best looking if you used any specific plastic primers / paints with good success please advise... For no more than I paid for this bike I don't see spending as much to on plastics to replace them.
4) Lighting - I was sad to learn that this being a two stroke doesn't have quite the electrical system some other bikes would have, thus i've looked at the forums and seen people adding a rectifier / battery for dedicated 12 volt accessories. Where did you mount your battery? Would you recommend just going with a battery and charging it if you ride in the dark often?
5) Headers... My headers are attached/suspended with what appears to be a small length of coat hangar wire.. I'm quite sure this isn't a standard yamaha part and probably was held in place via a spring if anyone could provide me with the proper photos of how this is supposed to be attached it would be a big help.. (Note: i've downloaded the electronic manual hopefully it will shed some light here)
6) Idle... It just doesn't idle well, before I go adjusting crap on the carbs are there any pitfalls to be aware of? should I wait until I get a proper air-cleaner to start dicking around with the idle ?
The bike has some other small issues namely bolts missing where the plastics attach to the frame @ the tank, and a missing gear clamp / where the header attaches to the exhaust pipe but those are easily fixed it's also missing the plastic the covers the radiator, which should be here today hopefully.. All in all the shee starts easily and runs great gives me a nice kick in the butt when I crank the throttle wide open through all the gears.
*playing around in some puddles after a day or two of heavy rain
*washdown after playing in the mud a little *note the tires!.
Arrow #1 -- What is this cover called? It appears to cover the water pump.... I haven't really found one in a couple searches online because I didn't know what it's proper name was...
Arrow #2 -- This is the area where the gap between the carb & air box is... Is there a part that connects these two items? If so what's it called?
Arrow #3 -- Exhaust hangar/spring etc.. The exhaust here is secured using coat hangar wire... What is SUPPOSED to be there?
Arrow #4 -- Tires.. Not particuarlly aggressive I drift and slide through corners riding trails the back tires break loose frequently and start spinning.
