WantABanshee
Everything posted by WantABanshee
  1. Hello, I am needing a cheap new or used adapter plate with filter. Let me know what you have. Thank you
  2. How much for the pro design plate and filter without the airbox? Thank you.
  3. It's getting to the point whee I cant find it at all.. It doesn't get easier as I move.. Does anyone have another shift star laying around?
  4. Am I missing something? The bike shifts like a dream all besides finding neutrAl
  5. I didn't snap a pic of it! No i did not notch out the neutral any. It is when the motor is running... My clutch is adjusted properly
  6. I read instructions on here about doing a shift star mod. I thought that I did mine conservatively but now I can not get mine into neutral. Does everyone that does this mod have this problem or did I get to aggressive with mine?
  7. ttt
  8. clutch ball and springs bought thanks quik shee ttt
  9. I am in need of a water pump impeller gear, water pump impeller bearing, water pump impeller seal, pushrod ball, clutch cover gasket and exhaust springs. I thought some of you guys might have spares you were wanting to sell. Thanks. Paypal ready.
  10. If they feel good then I do not have them changed out.. I always change the needle bearings that connect the rod the the piston Was the ring gap set correctly?
  11. pics of skid plate to [email protected] Thanks
  12. You payed through paypal man. File a claim through them.
  13. Your first response I felt that you didn't understand the complexity behind it. Sounds like you thought about it more than I thought. Locating the part and fixture so that the program can accurately communicate to the CNC where the 0,0's are etc. Good luck post up some pics of the fixtures I'd like to take a look. What kind of production volume are we talking about?
  14. So can someone tell me an exact oil that I can use??
  15. I'm not an expert but wouldn't it be nice to see an intake picture
  16. first question that should be asked is do you guys have the machine capacity to take on this project? What axis CNC are you using? What program are you using? MasterCam? Whos building the fixtures and locating the part? Its a very involved process good luck there is still a job market of this kind of education.
  17. So like a conventional 10w30 Valvoline would be fine to run in the tranny???
  18. I'm gonna need a few weeks to get the money together but I'm needing a few misc. parts. I need a plastic water pump drive gear. A water pump bearing Clutch ball some used front tires
  19. take the old flywheel puller and weld it to the old flywheel and pull that puppy off
  20. FINALLY FIXED IT TONIGHT!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks for all the responses and info guys... And thanks Savage (Chris) for all the help... ***************On the back of the plastic water pump gear the pin on the shaft rounded out the back of the plastic gear causing it to work but not under a load!!!!!
  21. I'm having the same damn problem.. Do me a favor if you figure it out let me know and i'll do the same
  22. Will do that. I feel like that is going to help but you said your buddies did it after a long time of riding. Mine does it after around like an 1hr of semi hard riding.
  23. got a pic of the sticky foam trick?? Maybe it is my impeller i'll have to take a look at it.
