acroadam
Everything posted by acroadam
  1. Ok. When you get it all packed, do u just take it to the ups store? How much is it usually?
  2. Thanks. Who ships it? Ups or USPS?
  3. How much does the engine weigh? I'm looking to ship it to Jeff@ FAST to get engine overhauled. Thanks
  4. I have a right side seal leak, and I'm fouling plugs within 5mins of riding. Getting it fixed in December
  5. Check your pick up coil.
  6. Make sure pressure plate arrows line up with arrow on clutch basket. I can move my adjuster bolt as well, but I can't move it when I pull the clutch lever in. Whats the gap between your pressure plat, and your clutch pack when you pull in the clutch lever? Should be a even 3/16 . The other thing to check would be your shift forks. Also, maybe the shift shaft spring has gone bad
  7. Ya, but then I would have to buy new pistons. I just bought new pistons, and has a fresh bore, not even 10 hrs on it yet.
  8. This winter I'm sending my engine off to one of hq site sponsors, and gonna do engine over haul. I'm doing this cuz it's 1997 banshee, and my right side crank seal is leaking. While it's apart its gonna get the crank welded, modded shift star, shift shaft spring mod, new bearings etc.. Since it's already apart what would you guys recommend doing? I've heard guys doing 4mill. But I don't think I can budget it this year. I'm just trying to get my engine reliable. Is a 4mill that's expensive to do? Or am I on the right track of just getting my engine overlooked, with new seals, bearings, and making it reliable for years to come? I thought about doing a play/dune port also. Any input? Thanks guys. Adam
  9. Ya I was gonna send my crank off to get welded too. What solvent can I use to clean off my crankshaft, and transmission?
  10. I've been watching your videos, good stuff man. Very helpful
  11. Good idea. Iam limited on money. Im gonna do it right. How would you up grade the transmission? Also, what cleaning solvent is good to use for cleaning inside the cases?
  12. Ya that's what I thought too. Is there anything you would do since the case is split, besides replacing my seals? Thanks. Adam
  13. I'm gonna be replacing my clutch side crank seal this winter due to bad seal. Anyways, I was reading in my clymers hand manuel the steps to disassembly the the bottom end. Now, Im just replacing my crank seal, I'm not over hauling, just a simple seal replacement, do I need to do all the steps in the book, like, remove transmission, clean the cases in soapy water, all that is good stuff, but I'm not needing to do that. So if anyone has replaced there crank seal in the past, what steps did you do? Thanks. Adam
  14. I have an outerware on it, and it didn't look dirty. What's the best way to clean the filter, air compressor?
  15. Hey everyone. I went to the dunes over the weekend, had a great time. Anyways, my banshee ran great. Great power, started up easy. Well on the last day, I went for my last ride, and it had a hard time staying idle. So i checked my plugs, and they were fouled out. I put a new set in then took it for a spin. After climbing a hill couple times, my banshee would not idle, it would just die. So I drove it back to camp, and I could not get past second gear cuz it didn't have any power. When I got to camp, took out the spark plugs, and they were both fouled. I don't know why all of a sudden I started fouling plugs. I did nottice i had a little gas leaking out of my bowl vent hose on the clutch side carburetor. Is there a chance I have a bowl stuck? Does messing with idle screws affect my plugs from getting fouled? Let me know where i could start to fix the problem. Thanks a lot. Adam. Mods are- Bored .80 over weisco pistons +4 timing K&n air filter in box no lid Fmf fatty pipes 27.5 , 300 mains 32:1 oil mix
  16. Did you do a leak down test,?. Sounds like it's running lean
  17. Thanks man. Ya I was riding with my friend Friday night and his headers was like a glowstick on his raptor
  18. I bought a couple quarts from auto zone, and it says it's for wet clutch. I was wondering if anyone else has used it? And if it's safe to use cause it says four stroke on it
  19. What about using a panty hose?
  20. I'm going to the dunes in a couple weeks, and I run no lid air box, k&n filter. Since i will be going to the dunes, do I need to get an outerware? Thanks, Adam.
  21. I was taking apart my clutch and I was wondering what do you use to dip them in to clean. I know once there clean, I need to soak them in tranny fluid for a day. But i don't know of a cleaning solution. Thanks. Adam
  22. How will I know if it's the crankshaft seal?
  23. Alright..I'm gonna take off my cover, and spray soapy water ,and see what I can find
  24. I have everything except yamabond and seals. Is there a chance it could be a keyway leaking?
