shakar
Everything posted by shakar
  1. shakar
    pipes
    i have a set of chrome fattys with the power core silencers. im looking for somthing lil diff.id like some pro ciruits or pt's or another low/mid but would be open to anything/everything ..... as long as there in decent shape . i have cash + the fattys and a bunch of bullit add ons and a set of asv clutch lever/mount and brake lever and other goodies .let me know what u got with pics if poss.maybe we can make a deal???
  2. i know its risky to mess with the stering stem , it doesnt even feel solid and im not sure how it looks inside? ............but has anyone ever cut and welded in an inch or so without a trip to the hospital?? i cant bring myself to buy an extended stem for 200+ and i allready have the 1''riser at the bars . thanks
  3. ....might as well get it trued and welded before it lets go and does more damage, i think its fast racing that does it for 75$ goodlck
  4. ive also been through this ........easiest way is get ur sawsall and cut the bolt and be done with it .
  5. take a look http://bansheehq.com/forums/index.php?showtopic=23546
  6. +2 flip the castle nut and have at It
  7. if you want to continue to use the burp bottle, zip tie it to the frontend behind the bumper and between the shocks.thats where i stuck mine otherwise just let the hose hang down past he frame
  8. there used to be a dude on ebay that sold a set or would put togather what you need and alot cheaper good luck
  9. i run at sealavel with 20cc domes and 145 comp and get by with 93.i think youll need some duel stage reeds for bottem/mid . arnt the v force more of drag top end set up??good luck
  10. maybe shes flooding mines would do that untill i got my carbs set rite. try taking plugs out dry and clean them and kick the crap out of it with no plugs to get excess petro out. put dry plugs in and try to start with no choke or 1/2 choke see if that helps goodluck man
  11. thanks for the clearup still 4-sale willing to do package deal ohyeah i have the prodesign easy drain water pump cover with everything needed to install 20 . its been abit since i been around and sold anything but im sure theres a few that remember buying from me and were happy thanks
  12. i have a pro design water pump impeller in great shape no wear on the shaft of it 55 to your door in usa and also a set of pyramid reeds and cages in great shape reeds never been turned over have plenty of life in them, for the specs go to dunkinracing.com and checkem out there not even close to cheap they come with #'s eched in the bottem of the cage . im not sure if thts how they come for the factory or if they been opened up a bit 70 to you lmk thanks
  13. kinda look like the dunkin cages.do they have any #'s or markings???actially i think the dunkin/pyramid only have 2 windows??
  14. also brand new set of breakpads for front or real teflon coated?? 10 to ur door, -stock skiddy plate good shape maybe need lil paint but up to buyer comes with the plastic slider 20 + -polished crossover tube 10 to you - ,01 blue uncut plastics no breaks/cracks has the lil white strechy marks on the rear fenders but in great shape fronts are great shape also comes with rad shroud and grill piece thats painted black 80 + for the set these Are perfect set for paint .im still digging more to come
  15. air box ready to bolt on has 6 holes in lid for more air flow. also have stock tyrods with good ends 20 + and a set of 450 tyrods with are a few inches larger the the stock banshee 10 + ill add more stuff for sale as i dig it out thanks for looking
  16. pyramid reed cages they do come with good woring reeds and will be polished when shipped
  17. i have a set of ss carier bolts that came out of a kit never used 12$ to ur door. i also have a set of pyramid cages with reeds ready to run.i have them seperated now to polish the cages ,these things are not cheap and have a design all there own with reed pedels on all sides ,4 on each cage . more info at dunkinracing.com 80 to your door also have stock airbow with lid and stock filter40 +, moose cr style highbend handle bars blue with moose bar pad 20+
  18. http://www.nossmachine.com/banshee_heads.htm scroll all the way down to the elevation chart . i believe ive heard that you want to stay under 160 for pumpgas.i run 20 cc domes at selevel on a ported motor and end up with around 150psi .hope this helps good luck now that i think of it not sure if bigbore would be diff??askaround??
  19. shakar
    A-arms
    u deff be better off geting the yzfz arms to match the shocks or some longer aftermarket banshee arms .its not going to ride right and will beat ur stock arms/balljoints with the longer shocks ..so ive heard good luck
  20. jets are sold thanks
  21. i got a set of pd 20 cc ill give ya for 20$ but shipping is going to be 110 $ sound fair??
  22. not being 100% sure what the silencers were was bugging mo .so i found a set of these on ebay there the original powercores with the bottem mounts cut . the cut mount in no way makes them loose /wobble when there mounted ther tight and not going anywhere ! http://cgi.ebay.com/ebaymotors/Banshee-FMF-power-core-silencers-exhaust-pipes-/180520454888?cmd=ViewItem&pt=Motors_ATV_Parts_Accessories&hash=item2a07db8ae8 thanks
  23. gigady gigady ......... got pm's but no cash yet so i still got it .
  24. i know there def fmf just cant remember if the sticker jus said fmf or fmf and somthing else but there older ones like i said i put the skull on . as far as the mounts thats the way i gotem on the wheeler.im sure somone else is sporting a set of these. id like to sell everything as a set ,maybe try there web site thanks though
