Okay, your going to have to follow me on this one:
I have an '06 Banshee which is all sotck with the exception of T5/Boost Bottle and foam filter. Still has the stock carbs and the tors.
I installed a rear brake block of plate 3 weeks ago before I put her away. Last week when I went to kick her over, it ran liike crap and I thought I was having catb issues.
Long story short it wasn't the carbs, it was the green/yellow wire that I didn't know I was suppose to cut that casued the rev limiter to kick in.
Anyway, before I knew that I had already pulled the left carb off and cleaned it.
Now here is my problem.
- Once I found out all I needed to do was cut the wire. I finished cleaniing the carb put the carb back on and put in 2 new plugs.
- When I went to kick her over. She started running like crap again (different kind of crap).
- Now she won't stay idle the first few kick, once she gets warm, she'll start to idel but then she'll start to idle really high?
- At first when she wouldn't idle, I thought I had a bad seal somewhere from the mid pipe or the the header, but when she finally started to idle high, I didn't think that was the issue anymore?
- Before all this she started every 1st and 2nd kick for the last 2 years I've had her. I can't understand how cleaning a carb, installing plugs, installing a block off plate and cutting the green wire could cause her to start giving me problerms?
Any suggestions?
