yammyboy3
Everything posted by yammyboy3
parts 35s everything bike part out
yammyboy3 replied to yammyboy3's topic in For Sale - Parts & Accessories
seat foot pegs lights sold -
SOLD 35 pwk boss intake 66mm cylinders stock cylinders cpi inframe drag pipes noss head with domes -
cpi inframe sold 35 pwks sold boss intake sold -
everyone please send a text or call my phone so i can help you better this sending messages back takes way to much time! 856 264 6004 tony or a straight email to [email protected] i can only send pics threw picture message from my phone the a arms are yfz450 and so are the shocks the shocks are black and red all of this stuff is in great condition i just lost my interest in quads CPI INFRAMES SOLD -
2002 BANSHEE FRAME WITH BILL OF SALE 300. +4 115MM ROD WIESCO CRANK 350. 66MM RUNNING TOP END WITH PORT WORK 300. NOSS PERFORMANCE HEAD WITH 20CC STROKER DOMES 180. 35MM PWKS WITH 6 INCH KN PODS 350. BOSS BILLIT INTAKE BUILT IN CROSS OVER TUBE 130. VFORCE 3 REEDS AND CAGES 150. CPI INFRAME DRAG PIPES SHOW CHROME 400 BOTTOM END CASES MINT ,, POLISHED 200. TRANY 150. HEAVY DUTY CLUTCH AND SPRINGS 130. MISC BOTTOM END GEARS 50. POLISHED CLUTCH COVER WITH BILLIT INSERTS 110. BILLIT WATER PUMP PRO DESIGN 40. KICKER 15 RADIATOR WITH HOSES 30 SKULL GRILL WITH POKER HAT AND JOINT WITH SHROUD 40 IMS 5.8 GALLON GAS TANK WITH PETCOCK AND BOLTS 200 SEAT NO RIPS 15 WHITE RACE CUT PLASTICS 100 HANDLE BARS 30. STATOR 60 CDI 50 FLYWHEEL 50 FLYWHEEL COVER 10 RICKY STATOR ADVANCED TIMING PLATE 30 WIRE HARNESS 50 IGNITION WITH KEY 30 HEADLIGHTS WITH BRIGHT BULBS 20 HEADLIGHT / ON OFF SWITCH 20 +2+1 A ARMS WITH RESIVOIR SHOCKS WITH +2 TIE RODS 375 BREAK SET UPS EVERYTHING FOR FRONT 50 BACK BREAK SET UP 75 SWING ARM 25 REAR SHOCK 30 STEERING STEM 50 AXLE 75 CARRIER WITH GOOD BEARINGS 50 HUBS 4/115 40 REAR LOWERING LINK 50 LINKAGE 10 CHAIN WITH 16T FRONT AND 40T REAR SPROKETS 40 ALSO HAVE 64MM STOCK BORE STOCK PORT POLISHED CYLINDERS 250 AIRBOX WITH KN AND ADAPTER 50 STOCK CARBS 60 THROTTLE CABLE 10 RED GAS TANK SHROUD 10 STOCK GAS TANK 20 AC RACING NERF BARS ALUMINUM WITH BLACK NETS 130. IF THERS ANYTHING ELSE ON A BANSHEE THAT YOU NEED LET ME KNOW I PROBABLY HAVE IT CALL FOR DETAILS THIS STUFF WONT LAST OR BUY THE WHOLE BIKE FOR 4000 856 264 6004 TONY
anyone interested in comin call or text 856 264 6004 bring EXTRA gas theres allot of trails and wide open paths
these are all take offs that are in good condition i want to get rid of if you need pics just ask i have no problem sending you some polished head right cylinder has some markings in it clutch springs i think i have enough for 2 bikes +4 stroker base plate vitos i think shifter forks 2 air boxes pro flow airbox adapter billit stock timing plate rear caliper doesnt look to pretty 4/115 hubs tors stock throttle cable carbs with tors removed idle screws installed has throttle cable thumb throttle coil voltage regulator stock tie rods front plastic mounts rear shock linkage stock grill k&n filter footpeg heal guards stock stock water pump stock intakes stock crossover tube 45t rear sproket 41t reat sproket my phone number is 1 856 264 6004 my names tony im not trying to get rich off this stuff but im not trying to get broke either
sucks he had to part out the bike but bought carbs and intakes from him EXCELLENT seller very fast shipping
sorry i wasnt on here for a while yes the pipes are for sale 200 shipped but if i can get a tank for the pipes i would rather do that
just a general question for you other highly modded people
yammyboy3 replied to yammyboy3's topic in Banshee Repairs and Mods
eh its really all around but more for mid top then anything -
i have the following to trade for an 5 gallon or a lil bigger oversized tank pro circuit platinums with silencers .. look great stock reed cages with reeds great condition air box stock carbs k&n with pro flow let me know i need this asap
well this is my bike as it stands as of now 2002 banshee +4mill 115 rod wiseco crank noss head 20cc stroker domes own portwork v force 3 reeds +4 timing pro circuit platinums stock carbs k&n filter with pro flow 66mm pistons 16t front 40t rear as of tomorrow 35 pwks cpi inframe drag pipes are going on 1. what kind of horsepower difference am i looking at? my buddy has an all stock shee with t6s and in the short and long run hes not that far behind me. 2. could it be that the stock carbs are holding me back? what else can i do to get my bike to MOVE even faster?
pro circuit platinums w/ silencers
i never got a text from anyone its 1 856 343 2545 -
for pics text 856 343 2545 -
pipes look great ??? no one interested -
just bought some new cpis off the member on here looking to sell my pro circuits good shape couple SMALLLLL dings look more like little pebles hit them stickers on silencer removed and polished asking 200 shipped if need pics pm me ill email you pics
gear saver 80w
it has a lil slack in the cable and no there not really worn at all
ok well for quite some time now in high rpm i have a problem shifting. from 3rd up it will not shift at high rpm i have to let the motor die down clutch it and then shift. its iritating me i just replaced the shifter forks with mint ones. the adjusting screw is right theres about 1 mm up and down gap. i have grinded down the shift start for smoother shifting i cannot figure this out what could it be ?? o and its a F.A.S.T clutch with heavy springs. could it be that the basket bushings are shot and it moves about a half inch ? what are some things to check ??? because its to the point were i have a chunk of skin missing off the top of my toe from trying to slam it into gear O it doesnt do it when the bike is cold that i have noticed that once it starts getting hot it goes retarded
no one needs any of this stuff ? if not going on ebay on monday
like it says i have allot of horse power and stock carbs are holding me back who wants to sell me some carbs i need everything to go with them except the throttle.. :-) and anyone wanna sell me a boost bottle i really want that extra 5 horse power as well and while your at it i need a can of black spray paint for that extra 3 horse power let me know what yous have :biggrin:
i have no use for paddles what kind of wheels do you have what other kind of things do you have laying around intakesfor 35s, bootsfor 35s?
yea i know banshees in and out i wasnt sure if they sold them boots for bigger carbs or not and what do reed spacers do also what is a 1-5 overide
vforce delta 2 reeds and cages perfect condition sorry one side of one cage were it sticks out to say v force i cut off for rad hose puposes pedals are great condition though 130 shipped pro cirucit platinims with silencers 200 shipped silencers polished stock polished head with numbers and lines from the rad hose hook up grinded off sanded then polished looks great 30. stock timing plate i kinda drilled to make it + i dont know what but no more then +4 15 shipped stock grill 15 shipped stock carbs tors removed with cable and idle screws complete carbs 215 shipped all are take offs cuz i ran into money and upgraded make some offers prices are kinda firm but make an offer anyway need pics i can text them to you
well i curently am awaiting my F.A.S.T clutch and i have a nice amount of porting no boost ports though can i hook up 33s or 35s to a stock air box????
