Sandking
Everything posted by Sandking
  1. Which carbs, elevation, and temperature.
  2. Is it ported, I'd like to hear how you like it when it's done.
  3. Message camatv hes the guru on the pv set up. If it has trinity domes your going to have to get new ones.
  4. Don't worry about timing right now
  5. So you still have it or did it go with it
  6. Wonder what happened to his 4 mill dm?
  7. 48-50 pilots , 68 is way too big
  8. 30$ shipped
  9. Pilot should 42-45, eek or eej needle, and plug chop for the main.
  10. Like this where are you located?
  11. Kompulsive Concepts for your wiring harness he's a cite sponsor and will take care of you.
  12. Call shearer and see what he recommends. I would figure up 2-3 sizes on your main jet.
  13. They are vent lines
  14. The carb slides also can't be mixed the little tab should point inward and the cut out towards the filter. The choke isn't the problem. If all else fails put some gasket sealer on both side of the reads in case they didn't seal properly when you replaced them.
  15. Did you put the cross over tube back. It's the black hose between the carbs.
  16. Try 50 pilot. The main seems too high but my experience is with a pwk carbs. I run a 150 main with a similar motor.
  17. I just tuned a ported bike with vf4's and fmf fatties. 32.5 pilots and 320 mains. The vf4's need one size up on pilot.
  18. Would rt side pipes have been better while leaning into the turns?
  19. How fast is a 501 yfz, doesn't take much to beat a stoke one.
  20. Try 330
