mailman
Everything posted by mailman
  1. Hey Gary, Do you want me to post up the Sniper vs. Shearer dyno comparison that I did on my Passion 4mil DM? I can list all the specs too if you like. I am working on a 70 HP gas 350 banshee and was wondering how the Sniper vs Shearers might compare to the T5's on the bike now. You know me...............always looking for a little more. If anyone in AZ has some inframe Shearer sb pipes or inframe Snipers and would like to lend them to me to dyno test on a 350 then it would be greatly appreciated.
  2. You may need to richen it up at the track a little if this was an ATV dyno. Just be careful and watch it when you first start making passes.
  3. Go Big Red. I really like how broad the curve is at the top. You are making over 100 hp for a 1700 rpm spread. I bet you can't wait until you get the right comp. domes in it. It should be a runner for sure.
  4. Pull the float bowls and clean them out. It sounds like some small bit of crud is getting stuck in the main.
  5. I would give John a call at Sandtoyz. He sells the double wheel rollers which I think are much safer. I think they are around 40 bucks. They are a wear item so you are better off buying a new one.
  6. or Plan B: Not a great "A" plan but a good back up plan. Go to Ace hardware and they stock a few different keys. Bring your flywheel down to get the right thickness. Then use your Dremel to grind to fit the length and depth. The thickness is the most important part. Don't forget to lap your flywheel to your crank to avoid future issues.
  7. It might help if you gave more info. like what carbs you are talking about. Some carbs the tube isn't meant to come out and some it is.
  8. Prices Reduced for quick sale. Carrier $65 Carbs $125 PM me if you want either.
  9. 5-2 needles are sold. 3-1 needles on ebay now and will be gone by Sunday.
  10. Intakes Sold and Shipped. Thanks Wheelman.
  11. Correction: The intakes are actually a CR500 bolt pattern which fit the DM cylinders. These don't fit the cheetah pv cr250 bolt pattern.
  12. Pm returned. Here is a pic of the intake side.
  13. Twin row bearing carrier in excellent condition with brake plate, c clip, and caliper spacers for stock size steel axle (not 40 mm drag axle). $75 Stock banshee carbs taper bored by Hall's Precision Racing in Glendale, AZ. These carbs work great with modded stock cylinders. They were opened up about as large as can be and still function properly. I don't remember the exact size at the smallest part but took some measurements in the pics where I could fit the calipers. The needle and seats are fairly new and OEM. These were off my personal 350 cc banshee but got shelved when I upgraded to a Cheetah. Stock needles in carbs. This machine work alone cost me $200. The carbs have the tors removed and come as pictured with the cable. I don't remember if the cable is for a twist throttle or not. I can put just about any main jet in there if you know what you want. Carbs only $150. These are excellent parts that I have been saving but just decided to sell. These are bolt on and go parts. Cheetah bolt pattern UPP intake boots for massive size carbs. $30 Yellow Oury ATV Grips for the guy on a budget. LOL $5 PM me if you are interested.
  14. Needle and seats sold. The metering rods are left for sale. $20 bucks a set. That is dirt cheap. Pm me if interested
  15. Cable is sold. Still have metering rods (needles) and still have the needle and seats.
  16. Here is a picture of the throttle cable.
  17. I have some Lectron carb parts for sale. Metering rods (needles 2 of each ) 1st set is size 3-1 XL and the second set is 5-2 XL both of these sets are good for running gas through Lectron carbs. I also have a metering needle adjuster I also have some needle and seats which are large enough for alky. I also have a throttle cable which is for a twist throttle and dual Lectron carbs. Each set of metering rods is $25, I will let both sets go for $40, Adjuster is $5, alky needle and seats are $15, throttle cable is $15 PM me if you want any of this stuff.
  18. Pipes are Sold. Will ship out today.
  19. I bought these off ebay last year to run on my 4mil DM but my bike was stolen before I could try them. I have about $400 into them but only want $250 shipped. They are 1 out each side silenced Shearer Chrome Big Bore, Big flange (53 mm for big DM). The pipes look really good. I repacked the silencers too. There doesn't seem to be any cracks in them at all. If you look closely you can see that one stinger section is shorter than the other when you compare the two pipes. I also bought these with 1.9 inch (49mm) flanges then had Metal Tech bore them out to fit the large flange DM which is 53 mm. I only want $250 shipped. I never ran these but obviously have no use for them now since my bike is gone. They are priced low due to the info. listed above. PM me if you want them or want to see more pics. Just PM me your email where you want the pics sent to.
  20. I just got off the phone with Mike at White Knuckle and he knew exactly what I was talking about. He found one in their "carb parts bin" and is shipping it to me. He said the part I need is not listed in the exploded view for some reason. Why the heck would a company not list a part in the view? Very Frustrating. Thanks for the input and help Jared. I appreciate it! BTW: Mikuni didn't even recognize the piece when I emailed them pictures. Oh well, I should be good to go now.
  21. They are 38 Mikunis. I think they are the older style TMX but they could be off of an OEM snomo or motorcycle. I just called Mikuni and sent him some pics. He said they can only get the aftermarket carb parts and not the oem ones. He thinks the carb is off of some oem bike or snomo. I am waiting for his reply. I went to your link and the exploded view is the same for all the sites but the part I have in the pictures is just not there. I also have the parts you listed, #42 and #43 in the carb plus the broken piece. Weird. I will give White Knuckle a call. They set up the carbs so Eric should know what they came off of. Thanks.
  22. Just called Sudco and they said they can't get that part. WTF?
  23. Thanks Jared, I will give them a call. I knew someone would know who has dealt with Mikuni carbs. Mailman
