Everything posted by THE GRIM RIPPER
2002 custom built cheetah
THE GRIM RIPPER replied to smokin350's topic in For Sale - Parts & Accessories
Bump for a Nice Banshee and a god awful, sick, nasty M3 that had I not been the upstanding man I am, been overcome with Jelousy and forced to hate on everything.... -
Pro Design is the best impeller made
+3+1 Arms 4:1 offset fronts, stock offset rears plus 2 or four axle
Why are modded Banshees so fast?
THE GRIM RIPPER replied to redwings's topic in Banshee Repairs and Mods
These guys have no Idea what the hell they are saying....... Get yourself a boost bottle, thats what makes banshees bad the Motha F*ckin bone. -
450's and 700's also have GOBBS of torque to hold as well, keep in mind!!!! 8 plates would be nice but I got 7, and I certainly dont have a lathe to mill my hub.... LMao Looks like my White ass is workin with 7, Na mean 4 Stroker?
Lotta info here guys.... And 4 Stroker, I have only run 6 Haevy Duty Springs in my clutch for as long as I've been riding, and I've raced MX and 2-3 hour long hairscrambles.... Man up, its not that bad. Im gonna go ahead and say if Dajogr is running close to 100 hp on a 4 mill and using the stock inner hub and pressure plate, it should be ok on my motor. So Jeff, I'll be placing an order with you for the inner hub and P/P....... Along with a clutch and a couple other odds and ends, If your products are being pimped by these guys I'm down. On a side note, as expensive as those GTYR Hubs are, they are some quality looking pieces. If those oil passage holes work like they are intended I'm sure they keep the clutch plates / fibers alot cooler. I'm not buying them, but they are nice.
Go with some T'5s or Pro Circuts
clean banshee for sale 3 grand
THE GRIM RIPPER replied to The Quadfather's topic in For Sale - Parts & Accessories
I cant BELIEVE no one has bought this thing for 3!!!!!!!!!!!!!!!!!! -
Shes such a fuckin loser but god damn if she didnt pull through with her looks in tact some how.... The commercial, and my girl stays watching some show where all they talk about is celebrities.
Spandex..... Like fat lady pants stretched over the rad. You can duct tape from the bumper to the handle bars. The material will also prevent the mud from building up and sticking. If you are allowed to pit, have a buddy waiting with a compressed H20 fire extinguisher to shoot through the radiator. And also have your buddies at pre thought out areas with fresh gloves and goggles (with ALOT of tear offs) If you are worried about your bike overheating, route the radiator overflow tube up the bars and zip tie it to your handguard NOT FACING YOUR HAND! Just so you can see if it starts to boil over and spit out so you know to do something about it (stop or whatever) I cant stress how inportant in races like this it is to keep the grips and your hands free of mud, so invest in some serious hand guards, seriously.
I wanna Bang Brittany Spears all over again......
Geuss your right there.... The mixture is burning.... Not exploding like a said, that would infact mean detonation. Either way, the mixture isnt igniting on its way in @ BDC..... Probably because there is basically a vacuum effect in the cylinder at that piont... No?
Dude.... Compression is EVERYTHING!!! Where is the spark plug in a diesel? With every PSI the Fuel air mixture becomes more volatile, No way w/o good compression any motor would run. Pour a little of your fuel on the ground and light it up, than try to make sense of the energy that flame is making..... Think that alone will move your Banshee? The mixtue in your cylinder isnt catching on fire.... Its flashing, and litterally exploding, because of the compression
Heres a little trick I came up with
THE GRIM RIPPER replied to THE GRIM RIPPER's topic in Banshee Repairs and Mods
See, Damnitt, I knew someone had to have thought of doing this before.... Oh well, I owned it for that split second that light bulb went off in my head. :cool: And BltdEyes..... Cordless impacts are gods gift, My buddy has two snap-on ones at work. I'm cave man hand tool status over here in my basement at my house. -
I already grabbed a Magnum Basket off a guy on here Speed Racer.... I think its probably the same people manufacturing the Boss one and the magnum one, they look identical
http://www.barnettclutches.com/products/of...?pp_make=Yamaha That pressure plate looks sweet! Plus they guarantee in never to wear, which it will I'm sure but it seems just the plate is replaceable which is a plus. I dont like barnett's clutches but their baskets and pressure plates look good. Any other companies makin this stuff? And billet inner hubs?
Some of you guys may have already thought of this..... In fact there may already be a post about it for all I know, but here it goes I was trying to get the 32 Mill off last night and was having a hell of a time trying to figure out how to hold the hub from spinning since the motor was out of the bike. What I did was took two fibers and a steel plate (beat fibers of coarse) and inserted them in the basket like I was installing them (fiber, steel, fiber) then I used to pair of vise grips and grabbed them while they were aligned and still in the basket. Then I drilled three holes right through all three and used a couple spare phillips head screws to fasten them together. This (once in the basket) will lock the inner clutch hub and the basket together..... obviously. And lastly, to stop the torque of trying to loosin the nut from spinning the crank, I used a folded up shop rag wedged in between the primary drive gear and the mating Clutch basket gear..... Which from what I could tell seemed to be harmless and worker well. You can also use this last step to remove the primary drive gears.... Just leave the clutch hub / basket on with the 32mm finger tight and wedge the rag the opposite direction. Hope this isnt a repost or whatever, more importantly I hope this helps someone who is scratching their head like I was.... :biggrin: So you guys know, I know there is a tool for this!!!!!!!!!! Didnt have one, and I like not spending money when I dont have to!
Does anyone other than Hinson make the inner / outer hubs Billet? I'm doing searches and all thats coming up is Hinson stuff (Great shit just really pricey) Im liking the quality of the Magum basket, in case anyone was considering it. Also I heard people talking good things about the clutch Jeff sells, I'm probably gonna go with that as well.
Yep, Your gear isnt protecting shit when its in your trailor! And on a side note, you seem like the kinda guy that might not strap his helmet (could be totally wrong but..) which keep in mind is just as bad as no helmet. Not being a smart ass, just looking out for a fellow rider!!
Sean Hasnt bought these yet??????????
It doesnt matter, Theres no firing order, the coil lights both of them @ the same time every time the pickup sends the signal....
Yep... Thats it, Thanks Brotha
The one holding the basket and inner hub on. Is it a 32 MM? I Kinda need a definate.... Thanks BltdEyes
Left my axle nut sockets at work.... I need to go buy one, what size? Thanks fooo's
Not worth the wire and gas you would use.....
