banshee(911)
Everything posted by banshee(911)
ok so ive posted a bunch of times the noise in my motor but still havent got it fixed can some one help i know what its not the only thing im thinking it is is the cases worn out but not even sure if thats it this is my second set of bearings in 3 weeks and theres a lot of vibration from motor and theres a noise i can feel the kickstarter vibrate when reving the engine sounds like a rattle
STILL NEED CASES
AM LOOKING TO GET A SET OF BANSHEE CASES NO BEARING WEAR
I GOT A SET OF DOUGLAS BLUE LABEL BACKS OR I GOT A SET OF RED LABEL FRONTSLET ME KNOW AND YOU GOT ANNY PICS OF THE CASES AND I WILL POST SOME PICS OF THE RIMS LET ME KNOW
my banshee is doing the same thing but was wondering if you hit the gas can you feel it in the kicker well good luck cause mine has done it for w while and i havent figured it out ive replaced the bearings on the brand new crank and still the same thing well best of luck, Ray
stock cross tube, small bore inframe CPI's or shearer's
banshee(911) replied to bigdaddy69's topic in Wanted
shipping would b 4.62 priority mail -
i have one if you would like but i dont need the boost bottle -
still no help but now its worse
banshee(911) replied to banshee(911)'s topic in Banshee Repairs and Mods
ok three weeks ago i purchased a vitos 4 mill stroker crank had my jugs bored to 80 over it has a mild trail port from dyno it has 5 degree advanced timing lightend flywheel 34 mm keihn,s i rode it about an hour and got behind some wheelers polarises they pulled out in front of me n stired up a lot of sand got it home the next day i heard a ticking noise so i took it apart n their was sand in my center bearings so i had my crank rebuilt with hot rod bearings had the clutch rebuilt also put it back together and i herd the noise in the side cover mind you theres about 5 min or so on new bearings i reved the motor twice and the flywheel and the nut to the gear to the waterpump came of putting huge hole in my clutch cover recently purchased a new cover waiting for cover now pockets getting low on funds what to do???? -
well as you all know that ive rebuilt my banshee twice and the problem keeps making things worse.ive put a vitos 4 mill crank in and that went bad so i had it rebuilt with hot rod bearings with stock rods 80 over pistons the heads been milled 10 thousands 34 mm keihins there was a grinding noise behind the side cover not sure think its the kick start idler gear now the fly wheel and the waterpump gear both sides came loose and the water pump side has a hole in it as what i put in my last post this thing is killing my pocket HEL PLEASE
actually it is a grinding noise and its behind the clutch cover and you can feel it in the kick starter and when you rev it up it gets worse and the hole is in the clutch cover -
oh ya and the crank was trued and welded by a machine shop -
well lets c just got the crank n clutch redone put it back together yesterday and same noise but now while it was running i hit the throttle a couple times and wouldnt you know it the flywheel came loose and the bolt on the waterpump side blew a hole in my side cover has this ever happend or has anny one herd of this b-4 its a vitos 4 mill with stock rods bored 80 over 5 degree advanced timing key mixing gas 50/1 ams oil the grinding was behind the clutch cover now got to get a new one found a brand new one of ebay guess im gonna have to pay some one 50$ an hour to fix it tired of messing with it waiting on my new cover now from flea bay buy it now 50 bucks
ok well hear we go again i just had my crank rebuilt my clutch rebuilt and my cylinders checked just got it back together and the noise is still there i can feal it in the kick starter @ high rpms help would b greatly appreciated
stock sleave and are they worth the $
awsome thanx brandon -
just did a search and wow that was funny guess theirs a fight in there but was wondering what every one thought about getting my cylinders resleaved id go a head n get new ones but i like the way these cylinders pull ne thoughts for 74 bucks each is it worth them
i do i run k and n filters on my 34 keihns
i just bought this vitos 4 mill stroker with stock length rods and then got in the sand with it i guess so instead of getting another new crank thought i could rebuild this one cheaper
ok heres what happend i just bought the crank and got in some sand i guess cause i posted there was a noise and tore it down posted it n got some remarks that it was the clutch basket so i went n had my basket rebuilt put it back together and still the noise so i tore it appart again and this time i spun the bearings just messin arround and herd some sand in it so i cleand the bearings with break cleaner oiled it put it back together and the noise got louder well got new bearings n hope its them seems so since the noise got louder but now i got all this money in the banshee just my luck it will b the connecting rods
im not sure it needs rods yet kinda hope not but ive already bought the bearings
well just took my crank down to get rebuilt n thought hmm hot rod bearings n possibly rods still waiting to hear if the rods are bad but if they are im gonna put hotrod rods 115's on it trued n welded lol what ya think
is it out 2 and up two ????????
ive got a set of +2+2 a arms and when i got the wheeler she kinda went over backwards n broke the ball joint to the a arm so while waiting for new i was gonna put stock a arms on but after i started puting them on the last one i put on was bent ne ways i got the +2+2 a arms fixed n put them on but now im looking @ it n the top a arm goes back n the bottom goes forward so did i put them on wrong or is this the way they go their pro line a arms not sure of the meaning of +2+2 a arms
i think the vitos super stock pistons are shorter but with a stroker motor am i to look forward to piston slap cause of the degree of the crank
ive got a vitos 4 mill stroker n now getting new crank the vitos is seperating and ive heard hot rods cranks come welded just wondering whats better also wiseco pro lights vs. vitos superstocks
are you saying that following him in a car is not an accurate speed
