Ive got a set off my 06 shee. Excellant condition. One season on them. PM me an offer if you like. I think I have a rear also just not the same color or year.
Havin g your domes custom cut is the better way to go. You will need to have your port timing adjusted as well. Take your bottem end, cylinders and head to your builder and the'll hook it up for you. Its the safest way to go. If your Cylinders are already ported for a 4mill I think Jeff at FAST has some off the shelf 4mill domes available now. Give him a shout. I have some for a 68mm bore in a 9 deg. and a 13 deg. Short and long rod.
Most any hardware store will have a 1/2"- 1" washer type spacer like fullthrottle has pictured above. that will really help with your problem. I dealt with the same thing and checked a few buddies rides and realized how far out the front hanger really had to be pushed out. Give it a shot.
Measure from the top of the rod and the top of cylinder. You should be able to KNOW from there. You'll be close enough to figure the length. Proly wont be exactly 54 or 58 but very close.
What the heck. I dont no why my Know is like that. Didnt mean anyhing by it.
I still cant believe they basically told you to bad and only offered to replace rotor for another. WTF. It amazes me how some of these people putting products out would rather kill someone before realizing there product is faulty and needs to be revamped.
Glad your not hurt David.
The early years from 200-04 i believe are the same as the early yfz. Im not certain what years they change but some of them are the same. Ive got lower yfz arms for a Raptor a few times. Just make sure there the same years if your buying individualy.
Awesome dude. I love the outside the box ideas. Ive got a couple things for that pocket for sure. LOL. Keep this build updated for sure. Cant wait to see it come together.
Ive used them both. I now run the Chariot setup and will proly run nothing else. There great on the bottem and all the way through. They are super crisp and took out that little notorious bottom end bog. I recommend the Chariot reed cages.
Where are u located? Im kicking around the idea of selling mine to build another one. Brand new ground up 4mill. Has one season on it. Documented the whole build here in the images section. Changed some things since then. Shoot me a pm if you want to chat and Ill help you out either way.
Yup. I can have one anodized for you from either vendor. Same with Stator Covers. There both a special order. I can also get you the Vitos slingshot type lockout. I need to put that one on my lockout sale. I do have some of the new Vitos items listed in the sponsor spotlight. Let me know what u decide Sandshots. Ill hook you up bro. Ill have to snap a pic of mine with the DD pegs I have on now. Plenty of clearance.
All you have to do is put a couple washers behind the footpeg. Before I got new DD pegs I think I had one washer in the rear and 2 in the front bolt. I did the same thing with my DD lockout to jbooker. A couple chrome washers.
Different pipes, CPI or toomey, intakes, reeds, k&n pods, advance your timing, coolhead to adjust compression, Dynatek ignition. Those are some bolt on mods. Then you can look into a 4mill crank, bigger carbs or a cub setup.
I have a slightly used throttle cable for a 2-1 and can also get you new if you like. Actually placing a Vitos order today.
Always try to hit up site sponsors before Ebay. We and the site appreciate it.
