Hey guys, selling my Banshee. Located in Watkinsville, GA.
I am selling my 2001 Yamaha Banshee ATV. I just completely rebuilt the motor. 3 heat cycles on motor and short 30 minute ride is all that is on the motor. Enduro gas tank mount on the back, no tank though, makes a great guard or handle. Polished aluminum rims. Bike runs great and cranks right up, idles well. Here is a list of recent service performed:
Completely disassembled engine and cleaned all parts
Measured crank, still within factory spec
Checked all gears, bearing, etc.
New crank seals
New output shaft seal
New orings and seals in bottom end
Freshly bored cylinders with mild port job
Bored to 66mm to make 370cc
New wiseco Pro-lite pistons, rings, pins, clips, small end bearing
New base gasket, intake manifod gaskets
Pro Design Cool Head with 22cc domes
New head o-ring kit and new head studs
New spark plugs
Rebuilt carbs
Uni Filter and Prefilter cleaned and oiled
New O-ring chain
Boost bottle
New Yamaha petcock
New stator cover gasket
New clutch side cover gasket
Fresh oil and coolant
The only bad thing is the front left wheel is pretty bent but doesnt affect the ride. Tires are also pretty worn out. Here is a link to more pics of the atv and pics of the rebuild process. Call James at 706-410-7714 or email with any questions. Thanks.
http://s188.photobucket.com/albums/z314/boxerworks/banshee/
