Everything posted by fastrthnu
the best place here to sell it whole is cycle trader. On ebay you get less. you might make about 2400 parting out on ebay. Like NYUK said try craigslist or try locally. If you part it out on ebay you stuff will sell for sure,. but you should note at least the 3% paypal charge and eBay charge so you come out on top. Just make sure the buyer knows before they buy. Motors sell for about 8-900 without carbs. rollers usually go from 750-1500 depending on how much there is and how much aftermarket parts are on it. Hope that helps a bit. Oh I forgot to mention,.. if you sell a chassis on eBay,. almost no body wants to deal with having this thing freighted. So completely parting it out might sell it all faster. Plus you can make a lil more on shipping.
Ill tell you about em,. they`re the best thing since sliced bread, beer,. n boobs. Get one.
I think people get the idea banshees are to expensive to mod because they are,. but only because there are 2 of most parts,. pipes, carbs, filters, reeds, pistons, ect.... but bang for the buck its worth it and still cheaper than moding a 4 choke to be of equal handling/speed. Just like the difference between a big block and a small block. a big blocks parts are more expensive,. but by the time you build a small block to have equal horsepower,. youve spent more.
hahah my girlfriend just bought that for me after I just showed it to her.
yea its people who hurt themselve then get an atterney and litter that ruin those spots alot. When I go there Ill pick up any garbage laying around mine or not just to try to keep it available.
I was trying to find a place locally to ride today and I found this field near by where these kids where riding dirt bikes,.so I pulled over and parked. They seen me ride and when I took a break they came over and asked if it would be better for me to ride on the mx track. There was an Mx track that went under a couple years ago and the gates where locked. But they knew a way in so I went in with em. I was worried about being busted,. but they said they come in every weekend and on day the owner showed up on a couple of bikes and didnt give a rats ass. So we rode it out. My forearms were killin me after like 5 laps. That shit was awesome. I cant wait to go back next weekend. Ill try to get some pictures n vids too.
yea Im at sea level too,. but the humidity is usually around 70-95% because Im right off the ocean,. plus the temp most of the time is between 80-90 degrees. I figured I should use a 300+ main, but IM not to knowledgable on this subject yet. Ill probley try about 320 right out first.
allrighty,.... thanx a bunch.
Im still running a stock box now,. but will be using the 2 into 1 in their kit. will 280 be to lean then?
I tried to find some info before asking,. and all I could find is that running with what toomey supplies with their exaust kit in average 85 degree weather at 200` and lower above sea level would be bad. SHould I buy the kit w/o jetting and get something bigger than 280? all I have now is up to 270. anyone in FL running T5`s? I dont wanna get 4 skits tryin to figure it out. So far all stock other than tors elim and open box.
straighten the handle bar.I take a straight edge like a 2x4 and square up on the back wheel and see which way the front tire needs to go. then loosen the castle nut on the end of the tie rod on the wheel till no threads are out then smack it loose with a hammer(with nut still on). take off the end, loosen the lock nut and turn the ball joint in or out how much you need. put it down and check it and make sure its right,. then repeat on the other side. hold the tie rod on one of the flat spots with channel locks or a wrench if it doesnt loosen easy.
a friend of mine from work told me when they ran the RZ350 in street bikes , in canada they also had a RZ500 available. Is this troo? and if sooo,. would one bolt up the same as an rz or yfz 350? That would be killer!!
What the hell is this suposto be
fastrthnu replied to Washburn's topic in General Banshee Discussion
what the f is that POS! that wouldnt fit a damn thing. its flared at the head! Idiot! -
see what happens. where in Fl you from?
im pretty sure toomey sells just screws for about $8. it wouldnt hurt to have 2 matching screws. price for the screws is cheap for the great time riding.
its easy,. take of the carb,. turn it upside down. there are 4 screws in the corners you take off. spray it all out in there with carb cleaner then with the gasket off (which you should replace) measure with dial calipers or something from the gasket mating surface to the bottom of the float (still upside down) 21mm. spec say 20-22mm. Make sure it moves easliy up and down when you turn the carb around to make sure it doesnt stick. To adjust the hight,. you just bend the metal tangs up or down. new gaskets,. put it back together,. (overflow tube toward the intake side of the carb) the filter side. alot of people put those back on backwards. you may not even need to take the throttle cables off for this.
do you mean it doesnt fully engage? as in when you have it pulled all the way in, the bike moves anyways?
I had that problem when I fired mine up for the first time,. but it was just the idle screws not turned in the same. so one slide was slightly open more than the other.
hahhaha yea,. I love that shit. Almost everytime I mention something about powerband people are like,.. (oh man you got powerbands,. yea a friend on mine put some on his dirt bike in 3rd and 5th gears and it flys now) or some weird shit like that,. and Im like oh yea? Im sure Im sure. The only boost bottles worth a shit are the ones that say NOS on the side.
Anyone taking any supplements...
fastrthnu replied to lastlegwarrior's topic in General Banshee Discussion
Halodrol is crap. Its androgenic properties gives you a little strenght you lose right after stopping it,. it has hepatoxicity which is why your only supposed to take it for short periods of time,. all the weight you gain (approx 10lbs in 2-3 weeks) is water and your blood preasure will rise. The only prohormone supplement out that was remotely close to real was M1T that has already been banned that mimicked parabolan/trenbalone acetate. -
what do they do?: they get hit with hammers! what are the benifits of taking them off?: you get to hit stuff with a hammer!
glad you got your bike done. that thing is hot! I got mine done a short while ago except for the seat. this shit dick didnt send it out till 2 weeks after I paid for it on eBay. So I wont be able to ride till next weekend cuz Its not going to get to me till Monday. Ruined my weekend!!! Cant wait to see some vid of that thing! post it up asap!
Is it coming out of that little stem under the radiator cap that doesnt have a hose on it going to the overflow catch can? maybe. the only other reason I could think of is a faulty cap.
