Everything posted by fastrthnu
holy shit boys, I got a good banshee vs lt500 story to tell check this out,... there was this one time who gives a fuck! Vs threads Vs suck my balls.
RZ passion 12 port 4mm motor and harness
fastrthnu replied to fastrthnu's topic in For Sale - Parts & Accessories
fk it then, I put it all on ebay. -
were the best place to put my bong in the banshee
fastrthnu replied to jack24piper's topic in Banshee Repairs and Mods
havent seen this thread in awhile. Anyways, if I smoked weed, which I have never touched or grown, Id come up with a better method such as uhm rolling papers that fit in a baggie in the storage or pocket or wallet, that way, if I wanted to lower my riding potential quite a bit, I could do it more efficiently. I drink, but not 1 beer when riding, just something about goin 50mph through the woods or doin 70mph wheelies I like to have my whits about me. Driving is another story. -
use a hedge trimmer or a skill saw, or ox-ace torch. I think theres a 311 page manual at the barnes and noble on cutting plastic,... I recommend that read right there before tackling such a feat.
Engine is 391cc, made 160 psi before pulled apart, makes 180+ at sea level fresh. Pistons are good, needs hone n rings. Does NOT need rebore. Head milled and stroke clearanced, 4mm hotrods crank, rz powervalve cyls 12 port 65.5mm, vortex billet clutch basket, f.a.s.t. plates, std gearing, has no flywheel or reeds. 200w stator, full rz conversion harness, cdi, servo controller, servo motor, ect. exhaust flanges, everything other than pipes and carbs for this conversion. Very good hard pulling all around motor. If I can find them, I have some 34mm flatslide carbs too. Sell your std motor for $800, and get this nicer one for $1100 total inc ship n paypal fees. I will part it upon payment for 600 + shp for cyls, pistons, head, harness, n stator 275 + shp for crank 150 + shp for cases 100 + shp for clutch 75+ shp for full tranny 20+ shp forks n drums other misc, ask.
Moving back to Ft lauderdale or Miami, time to sell a quad. Drd full pipe, amr cdi, k&n lid off pro flo, cam mod, +2 front extentions, propeg nerfs. Great compression. 0 problems. $2750 w/o hypers wheels, 3k with. S. FL. Shannon 239 246 7033.
its to high for pump gas, but not to high, wh y is it off 5 psi on a fresh top tho?
I have no doubt that pretty much any pipe you put on a banshee is going to put it into the 40`s. For sure with the lid off. Those are stock numbers i put up there. But do the same with the yfz, though it wont gain as much power per mod in most cases, itll still put it mid/upper 40`s and possibly very low 50`s esp with lid off and the cam mod which technically isnt a bolt on. Then you have to take into account that the pipe on the banshee will raise the mid/upper range of power, and drop a little bottom, a nice full system on the yfz will broaden the curve still early and late. Im not sure, but yamaha may have already taken the cam mod into consideration with the 09 model. I know they changed some of the design flaws from earlier models, and I really dig the factory long travel. As I said before, stock vs stock the yfz dominates. If you put a pipes banshee vs a stock yfz, its a closer playing field, after that there are to many variables, as they are 2 different worlds, and at some point, way into mods, the banshee will most likely come out ahead. I pick n choose atvs much the same as I would cars. I like a fast car that handles all around in any area of driving, then I like drag racing cars only. Now if you asked my what my favorite would be over say a 70 chevelle or 69 camaro vs a Z06, Id say one of the first 2, but if I had to pick one it would be the Z06. If I could have both, I would. But my z06 would remain near stock, with a few easy bolt on mods, and the early model, easier to work on, lookin good with some fat back halfed tires and big block, cheaper to modify and work on turning heads all over would easily domintate the newer car, but only in a very limited range of driving/racing. Stock vs stock the new 427 would beat the old one. In a perfect world Id have both. Just as Id choose the banshee for drag only over anything else, but over all the yfz has to be my pick, and trust me, as I die hard banshee fan Ive done alot to make an all around banshee, and when I rode the yfz, guess which one I chose to keep when it was time to pick n choose. Eventually Ill have a serious strip banshee, as Im sure I can do more with it for that, but for average all around rec riding, the positives outweight the negatives. The same if I was hillshooting or duning, but all I have are strips, woods, and mx tracks where I live. Had I decided to race an LT500 when I had my banshee and won, I wouldnt be like thats right those zukis fucking suck, ID say nice try, you got a nice quad there, but something needs work. Maybe something was wrong then next run he smoked me. Then I look like an idiot. If a banshee beat me now, I wouldnt expect him to down my bike either. Depending on how far you take it, there is always something or someone better with or without somethng different. If someone talks shit with an equal or less than equivelent machine or skills and you beat him, you didnt beat a make and model, you just beat him and his quad. I had much time to type all that between poker hands btw.
A stock banshee is 386lbs, and 36-38hp @ approx 8000rpm. The 09 yfz 450 is 372lbs, and will make 38.5-41hp at around the same rpm range. These are 0 bolt on numbers. Of course the hp rating varies on temp/grain, n alt. These to consider, plus the torque on a 09 yfz 450 is 25-27ft/lbs pretty steady from 4-8k rpms. The banshee doesnt even hit 20 ft/lbs until about 6.5k+ rpm. Even with the average pipe, that torque would remain below that line until much higher rpms. Bolt ons on the yfz make a decent amount of hp gain too, Ive seen dynos of dasa pipes throw up to 13hp to a yfz motor. Stock for stock, the 450 wins, piped banshee vs stock 450 depends more on rider weight, tires, and skill, bolt on for bolt on, is to variable to really say, but Id still favor the 450 untill stroke and porting come into play also, then the banshee begins to dominate. Im sure a well done 535 banshee would take a well done 535 yfz. On the closer to out of the box rides, with just bolt ons, most of the time the yfz will have the advantage, even if the banshee makes a couple more hp, with better trac, lighter weight, and a ton more off the line torque, and comparable top rpm peaks the yfz has the slight advantage.
YEA!!!! There are a few members on here Ive taken out over and over against my yfz. One is a good friend of mine who has a ported t5 shee, been racing for years, and races streetbikes to and is a member on here if I can get him to chime in, in sand and asphalt, over and over beaten by many lenghts by me. My prior banshee had it not been on a -2 and +4-6 would have rocked my yfz tho. All I have is a full drd pipe, cam mod, filter, and amr cdi. Its not like whoa crazy, but its a quick bitch. I love banshees too tho,.. no doubt. My next banshee is goin to be a 10mm+ strip only. They are better dune/drag nowadays, I had everything on my banshee for mx n woods, and I parted it out to finish my yfz and get a bike cos thats the riding I do most and its hands down better on the track and woods. BTW, who gives a fuck, you all sound like the 2 stroke klu klux clan. Its just as retarded and shit talking banshees on the 4 stroke sites. All I can think is they took err jobs!!!!
unless you have alot of road, they yfz will woop your ass off the line unless you got some stretched out n done up motor. Unless your racing an idiot. I stomp the shit out of anyone on a stock swinger with my yfz till about 250-300` then they have to catch up. alot of the time banshees will catch back up on the long run, but all the torque out of the hole is nice. In sand Ill even leave in 3rd and it just goes. In the sand you can really rev a banshee up into its power and keep the wheels in spin and whoop his ass tho. the 09 yfz has a better setup and more power than the previous years. just with a good pipe/jetting and easy mods, theyll break 50hp easy.
jetting and compression question
fastrthnu replied to banshee400nut's topic in Jetting & Exhaust Forum
i think 110 would be fine in it, maybe even 105, and lower alt. will need a fatter jetting. cant tell you exactly what size(s), but thats what plug chops are for. -
maybe a blown gasket/o ring is letting water in that cylinder.
Passion RZ 12port 4mm top end
Ill post pics up later today or tomorrow. Ive been super busy, and they havent been split yet. Ill send you a pm with pics as well. -
Ill sell the cases for 150 nothing wrong sept the typical chainchip. -
Guess febay it is..... -
dasa racing any good?
fastrthnu replied to bitterbillybitchcakes's topic in General Banshee Discussion
IDK about 2 stroke work, but they are the fuckin shit when it comes to 4 strokes. -
This is for milled/4mm clearanced head, pistons, new rings for one side needing rehone, harness stator, and cyls. Everything to make this setup work. Well worth the upgrade, esp if you dont already have a ported motor. These cyls are ported for a 4mm crank, and as of now I still have the bottom end. Considering I really dont want to let this setup go, how rare it is, and expensive the work is, Im asking $650 plus shipping. This motor made 182/160 psi when taken apart. the pistons have about 20 minutes run time from brand new.
everything is sold except a stock blue seat, rear brake assy, motor/carbs/harness, rear shock, bolts, on off switch, and front brake master cylinder.
I sold someone a flywheel that was waorking, but when they got it, claim they have no spark. Tried another and got spark. Idk wtf is up with that, should work n gap just the same,... any one have 2 cents?
traded a banshee,...... for a dodge,.......
i used 2nd on my banshee and feathered in the clutch, 2nd on my yfz, and sometimes even 3rd on the yfz in soft terrain.
my new mechanic wears a thong lol
fastrthnu replied to Nor*Cal Kid's topic in Banshee Repairs and Mods
still no pictures!?! you just failed I just took my ex to the motel 6, and the only card I had on me declined! I failed too! -
If you get the chance you should come to the race on the 22nd were running both TT and flat track we are running both the $$$$$ classes! word, Im commin to that one!
front rims and tires sold handle bars and asv lever sold -2 swingarm sold
