austin
Everything posted by austin
  1. all sold, thanks guys!
  2. single is sold, pair still available
  3. I picked up a pair of works shocks for my shee so I wont be needing these anymore. Good condition with normal wear (see pics). Never been off any jumps, rode mostly on country roads. The single is from a yfz front end I bought a while ago and the box came with a big hole in it and only one shock! Ive never used it, been sitting for about 2 years or longer. Id like to have $200 shipped for the pair and $80 shipped for the single. Paypal preferred. Thanks fellas.
  4. I dabble....haha. Too many engineering classes I guess.... About the exhaust- If you have your port timing where you want it and have it blended through to the exit and polished somewhat you should be fine. I dont think increasing that inside diameter is going to net you alot of numbers, if anything it will reduce exhaust flow velocity and take away some bottom and mid rpm power. Also you wont gain anything if the I.D. of the exhaust port is significantly larger than the I.D. of your expansion chamber inlet. (more turbulence, less flow, less power) EDIT: theres some cpi pipes in the for sale forum that popped up today, better hurry!
  5. I think if you were to move that wall back would increase turbulence where the intake is trying to turn that corner and go out the transfer exits. You want the smoothest flow, which is helped by reducing the radius of that corner, so Id leave it. But what do I know, haha
  6. Wow, that was fast
  7. http://yfz450.theatvchannel.com/invision/i...588&hl=arms
  8. Theres a couple guys here that have a set of yfz arms in the for sale section, check that. Someone on yfzcentral.com always has some stock yfz arms for cheap, thats where I got mine
  9. Nope, not that I know of. There was another guy doing a fuel injected E85 setup on here. I decided against it cause I didnt want to hassle with a purge tank. Would of smelled good tho :cool:
  10. super fine steel wool and mothers polish
  11. Ive got rox risers on mine, jumped all kinds of stuff no probs, look good too, imo. Id snap a pic but its all tore apart. Bump for a good guy.
  12. How much for the impeller
  13. Ill take the carb setup, pm sent.
  14. Ill take the filters if they fit stock carbs. Email sent
  15. Just as it says, good seller, fast ship, no lies here
  16. Ive used engine ice with good results. Ive also used water wetter or whatever they call it with good results, I think that stuff is made by red line oil
  17. Ive got odi locking grips on mine, comfortable and no slip. I think they only come in black but could be wrong
  18. Got an LED one off a 05 or so yfz on mine, looks pretty sweet, wasnt hard to mount either. Got it cheap off yfz central.
  19. I build and test experimental combine harvesters
  20. Ill take these if dave5.0 doesnt
