Everything posted by 3
  1. Here is the link Washburn, http://www.bansheehq.com/forums/index.php?...cutting+swinger I do know how you search but it took me 1 min. :yelrotflmao: , because a ive been reading it last week. Blue Deuce, what about cutting the other end of the swingarm? where its welded on the pivot. Tell me what you think, i think it could be easier with less cutting and less welding and in doubt we can had gusset, just an idea, dont know if its doable i need to have one in hand to think about it more.
  2. http://www.toomey.com/, go in the ``Tech documents`` and then go read the ``Banshee idle screw`` You wont need anything else, except something that you will put inside the carb, where the slide goes, just to stop you from drilling in the other side of the carbs. i.e. Piece of wood, socket. Good luck :thumbsup:
  3. Pictures of nerf bar please?
  4. There is helicoil in a lot of aluminium part or casting who need threaded holes. They are a lot stronger than direct threads in aluminium so i would go for that fix. They are fairly easy to install if you have some skills. It's just tap or redrill the hole and tap than you install the helicoil. The only trick to it is to use taping oil at all the steps. Good luck man.
  5. Well i guess that stop the debate because there is no general answer to it. I think i will probably buy the shocks anyways and start from there. Thanks guys
  6. Alright, but whats going on with the YFZ shocks, they measure 15.75 and that doesnt fall in the LT category when you put them on a banshee. I dont want to be the smart ass, but i think the line is tine with that subject.
  7. Ya i know what you mean but 16 inchs is not a long travel shock right???
  8. Ok with all that said, a +2 a-arms will accept a +2 shocks, +2 over stock shock length i mean. So if i do the math again those 16.5 shock are a pretty good fit for standard travel +2 +1 arms, am i right? Thank for the help and man everytimes i read one of your post it take me more time because of those bouncing ... its just not good at work :yelrotflmao:
  9. Is a 16.5 inchs long Elka shock will be to long for a +2+1 a-arms set? Iam getting a bit confuse with all the different lenght of shock. I do know that the stock length is about 14.75 ctc, but i never use +2+1 a-arm before. thanks for your help
  10. 3
    Elka shock swap
    Did you say that the 16.5 shock is to long for a Banshee front end??
  11. 3
    A-arms/shocks
    What kind of riding you are doing? I know 670$ is enough to shop for a lot of different brands but i will have to pay a good deal of money for shipping so buying from one place is a good option too.
  12. 3
    Elka shock swap
    I forgot to mentioned, shocks are w/o res or piggy back and 16.5 in length and will go on +2+1 a arms.
  13. 3
    Elka shock swap
    Hi guys, my question is, can i use a set of front Elka that were on a YFZ450 to put them on my Banshee?? I am going to run into the same problems as using the 450 stock shocks or it will bolt on perfect?? THank you
  14. 3
    A-arms/shocks
    Washburn, I was reading one of your post, did you bought your LT +2+1 kit?? Why did you decide to go this way??
  15. 3
    A-arms/shocks
    Thanks man for this info, there is not a lot of words on eyeball on the forum. I've fonud a compagny who sell them with line and clamp for 670$ what do you think?
  16. 3
    A-arms/shocks
    Ok, but it another compagny who sell there products, anybody with experience with their a-arms??
  17. 3
    A-arms/shocks
    That was a good debate guys :thumbsup: . I keep on shopping and the more i look the more options i find. But i will definatly wont go with ASR. I have found an a-arm kit that is interesting, line clamps and everything made by Eyeball. I search on the forum about them and didnt find much. So if you have any info on them it would be apreciated, that seem a pretty good kit to me. Thanks guys for all your help.
  18. 3
    A-arms/shocks
    Thanks a lot for all your inputs guys, man i love this forum! EastCoast, you confuse me a bit, you said that ASR is bad and good at the same time?? I research a lot on the forum about them and the opinion seem to be really 50/50. I still think its a good deal. Climb any Hill, that ebay kit is cool but i just read a lot of bad about Fullflight. And by now i will really look into the for sale section, i wish ill have some luck like you guys did.
  19. 3
    A-arms/shocks
    Woooooo!! what happened?? damn technology!!!!
  20. 3
    A-arms/shocks
    I didn't hear that everythings was perfect with ASR and i dont want something cheap, just a good deal. Thats why im thinking of buying everything at the same place, to save on shipping.
  21. 3
    A-arms/shocks
  22. 3
    A-arms/shocks
  23. 3
    A-arms/shocks
  24. 3
    A-arms/shocks
  25. PM me if you still have it
