KRMit
Everything posted by KRMit
  1. It's really not a problem for me to live with it the way it is. I just want to make sure it's not causing any problems.
  2. Since I've had my Shee the choke won't stay pulled. I can hold it out while I crank her up and rev it a few times with the choke pulled, then it seems to run fine. This isn't much of an inconvenience, I just want to know if this can cause any problems. Thanks!
  3. No fuel filter. I know where the pilot and main jets are, but where's the needle jet? This problem has been very persistent. I don't really think it's fuel flow cause both cylinders pull pretty good at full throttle. This has been bugging me since I got my pipes a year or two ago. I may have just not noticed it, but that seems to be when it started. I'm tempted to go back to the stock pipes and see what happens. I'll probably break down and try the things you've listed. I do have an extra set of reeds so I can try swapping. I'm including a pic of my reeds in this post.
  4. This has been a problem for some time and I've since rejetted and cleaned carbs.
  5. I took my airbox off tonight and made sure my throttle slides are in sync. I started revving the bike up feeling the exhaust. One side was firing more consistently at first, but things evened out once the bike warmed up some. I slowly revved it up until the powerband started kicking in and suddenly the left cylinder cut out completely while the right revved on up. I swapped the spark plugs, but that didn't make any difference. Anyone have any ideas on where to start? Can I safely swap the plug wires or does that mess up the firing? Could it be due to the exhaust? I bought the pipes used and I don't remember this problem with the stockers. I've never replaced the packing either.
  6. He's probably looking for an inline coolant cooler. I wouldn't think one would make a lot of difference, but I know www.rockymountainatv.com has them. You could also maybe look on eBay.
  7. Why do you need those reeds?
  8. Is that the skid plate you're referring to?
  9. I'm looking for a rear chain guide and case saver. Anyone know where I can find these things cheap?
  10. I need the upper-left a-arm and a stock front shock. I had a spill. Send me a PM or reply please.
  11. I wrecked my Shee... again. Does anyone have a used front shock (preferrably yellow coils) and/or an upper left a-arm for sale? Thanks.
