If you get a good stock crank the berrings should be good. Just have it checked to make sure it is ture, then the builder will weld the crank pins so it cant seperate or get out of phase.
If your dead set on a new crank it would be dumb not to do the 4 mill stroker. Your looking at $380 for a stock crank when you can get the stroker from FAST for $430
You dont have to get your cylinders ported right now for the stroker. Everybody says that it wont run to its FULL potential. Well a non ported stock stroke engine doesnt run at its FULL potential ethire.
If your just wanting to get this thing running and want a new crank I would go with the following.
4mill long rod crank with extra weld
Wiseco 795 series pistons (required for both stock stroke long rod, and 4mill long rod)
Run the spacer plate between the cylinders and cases instead of cut stroker domes for a cool head.
The only extra it will cost to build will be the little difference in price for the crank and the spacer plate.
I just got a set of cylinders bored from FAST with 795 Series pistons, gaskets, and shipping for $320
So your looking pretty much at that price plus the cost of the crank and spacer plate.
josh
