Nope, only one rod and one ball in there. Yes the ball should be between the rod and pancake CDA.
Remove your clutch cover. Loosen cable at clutch lever all the way. Push lightly on clutch actuator arm untill you meet resistance. While holding it there, adjust the allen screw on the CDA (pancake bearing) untill it lines up with the arrows on the actuator arm and case. (* my CDA is adjusted almost all the way in, not out) You should be able to get it real close, if not then something isn't right. Tighten jam nut. Before you put your clutch cover back on, take up the remaining cable slack with the clutch lever adjustment leaving a tiny amount of play so you're not riding the clutch. Work the clutch a few times to check for any binding. Look down at the pressure plate to make sure it's pushing out evenly about 1/8 to 3/16". If all seems ok, put the cover back on, fill with trany fluid and coolant...test ride.
Hope this helps, good luck.
_Ryan
