Snopczynski
    2
  1. Need a better side shot of the header tubes.
  2. Did you originally check the compression with the motor warmed up, and the throttle wide open while kicking?
  3. You need to check squish before you run it anymore. You should have checked it before you even started it.
  4. pro circuits. Dont even consider the dynoport pipe.
  5. Cost on them is no different than the keihin pwk, same price range.
  6. Which cylinders for the 421? I run TM's, I dont see much difference from pwk's as far is it runs or with tuning. The TM's are easier for me to tune, but I know most of the baselines and have always ran them.
  7. You may have to go down to coos bay or north bend to watch it.
  8. I haven't ever seen a banshee topend just wear out and get low on compression. If the compression gets low, its usually because something happened, like it ate some sand and the bore is scored. I voted for when it blows up.
  9. Unfortunately the LT500, several times.
  10. ? He bumped it, and now he hasn't even checked it?
  11. Well the plug shouldn't tell you many lies then. I never do plug chops, I just look at the end of the plug for ballpark on pump gas and go off of feel.
  12. They are in Canada, but their product looks identical to the ricky stator stuff.
  13. What octane fuel are you running?
  14. Tell RDZ you want it to be a reliable fix, and they will tell you what needs to be done.
  15. I would set it at .045" with fatty pipes. If you go to a better mid-top pipe I would increase it a little more.
  16. RM Stator looks like the same stuff as Ricky Stator.
  17. Put a driveway alert on it, and put the receiver in the house. They are probably going to steal it when your gone though. We have a house alarm, with sensors in the garage on the doors.
  18. If it is a trinity kit, it should be a 35mm pwk.
  19. You should have checked it warm to get a more accurate indicator of where your at. I dont see much reason to use cold numbers as a base.
  20. Listen to the guy at RDZ he is gonna be the best person to talk to about this. Rudy Kurtz is a drag motor god. Give him the cases and see where you sit.
  21. What about for a set of Mikuni Tm 28mm Flat slides?
  22. I dont think they are required. I haven't even been pulled over for a sound test in 14 years. If your ride like an asshole, the rangers will treat you like an asshole.
  23. your gonna need to familiarize yourself with the layout. There are a lot of tree islands, trails, and roads at Coos Bay. You could easily get lost out in an area and have a hard time finding your way back. Its not like Utah where you just ride across open sand towards Sand Mountain.
