Snopczynski
    2
  1. Those are the specs, I posted them on here. Those are for mikuni 28mm carbs, but should be some what close. You can also llok in the pinned jetting setup thread at the top of this forum page.
  2. So your carbs are set up with these internals? Slide: 2.5 Needle: 5L1 2nd from top Pilot jet: 30 Main jet: around 380-390 Float height: 22mm Nozzle: 175 (P4) Air screw: 2-2.5 turns out Needle seat: 2.5
  3. I have a set of 28mm Mikuni TM's bored to 30mm on my uncles 460cc cub motor. You need to make sure you have the correct nozzles, needles, slide cutouts, and neddle/seat for a banshee installed in them. You should be close on the main, but those other components are crucial. Info is on the HQ for the other specs.
  4. http://www.savetheridersdunes.com/
  5. The forest service needs to chill out. We already have a miniscule amount of dunes to ride on compared to years and years ago. Now everything is covred by grass, trees, or its closed.
  6. 205 is the shut down point on em. Running around 175-190 is ok.
  7. You have to convert to dc to run it off the bike. The only other option is to install a battery and charge it in between night rides. None of the HID or LED high output runs off ac.
  8. My bike never gets hot, so I am not worried about it.
  9. It looks very bad, not mechanically bad, but Michael Jackson bad.
  10. Ummmmm, well your gonna be waiting along time for the prices to come down. Did you price one out through me?
  11. Your mods and desired power output type are going to be the key factor in this. Without knowing either one there is no way to help you.
  12. this one isn't an xmitter bar, its a reflex bar. Those are 4 spot bulbs, not a bar of flood leds.
  13. Yeah I put one on a Rhino and decided to try and do one on a banshee.
  14. A 2:1 can have better topend than dual 26mm round slide carbs. Has either bike's motor ever been apart? Are you sure all the parts were identical between the two bikes?
  15. Well I finished up a little project tonight. I put a Vision X Led Light bar on my banshee. I custom made a mount, just need to get it powdercoated now. I rode the bike down the road, and holy balls this thing is bright. You do have to have a DC Conversion done to run it.
  16. Thats a regulator problem, not a stator problem. RM and Ricky Stator are the same product=SHIT!
  17. T5's if your gonna be DRAG RACING. Pro Circuits if your gonna be MX RACING.
  18. Pro circuits are nothing like toomey pipes. The pro circuit is a low-mid pipe. The T5 is a mid-top pipe. It depends on how you want your power delivery, and what parts you already currently have and dont intend to change. All the things you listed are typically considered mid-top parts, or mid-top engine work.
  19. "Single carb" search result
  20. use the search, the info is on here.
  21. Is the choke balance tube on?
  22. nope. I have a dyna cdi, and I dont run one. I program mine too though.
  23. I say 119 hp. That thing ought to fuckin haul ass!
