Any ideas on how I can clean all of the strawberry milk (coolant/gear lube) out of the case? I was thinking about denatured alcohol. It should soak up most of the "water" moisture. I have the clutch cover and the impeller out. When you say it is the water pump seal, i am guessing you mean the rubber piece mounted in the case cover that the impeller sits in?
