What's up fellas? I've been a lurker for years. I've had my Banshee since 95 and I'm lovin every minute of it.
I picked up my Banshee back in 95 for $1k.
Ripped the airbox, TORS and dual carbs off right in front of the guy I bought it from and threw that sh!t in the trash.
Stripped it down to the frame sand blasted it then rattle canned it white... big mistake, but oh well, there will be a new beginning soon.
I put all the mods on it in my signature and literally broke the engine in down at Pismo Beach.
I always thought the trans shifted overly notchy and just figured it was the nature of the beast.
I planned to straighten her out, but I live under the philosophy that if it ain't broke don't fix it.
So fast foward 16 years to Sand Mountain, NV where I was out riding in the dunes for about an hour.
I needed to shift down into 2nd and the shift lever just moved down but didn't click into 2nd, so I kept it in 3rd, worked the clutch and climbed to the top of a dune and parked it.
Shut her down and tried to negoiate 2nd gear by hand, no dice.
So basically it won't shift down to second from third.
I was able to ride back to camp in 3rd and 4th, and I didn't hear any crunching, so I thought that was good.
Rewind 10 years ago and I replaced the clutch with all new OEM parts.
I know for a fact I didn't adjust the push rod properly and just lined up the arrows on the clutch actuator to the motor by the perch adjustment. I know, I know...
I never took the basket off, so the shift shaft arm might not have the proper adjustment to the shift star pins.
Thanks to the Banshee HQ forums I now know a ton more about Banshees, and I'm more than capable to adjust everything and even split the cases if need be.
I'm fully prepared to buy all new clutch actuator parts and shift shaft parts including the F.A.S.T. modded shift shaft with the light spring, or should I use the OE Torsion Spring.
I plan on getting a Magnum Basket, new OE inner and outer pressure plates, F.A.S.T. HD Clutch Kit, Modded Shift Star, Shift Pro w/OE Spring, Billet Neutral Safety Switch and new Pancake Bearing for the pressure plate adjustment.
I will also pick up all new seals and hardware.
Do the cases need to be split in order to replace the shift shaft bushing on the leftside of the motor?
Sorry so long, but it's also kind of an Intro Thread too.
Thanks in advance everyone.
