Its all about form if u dont have it ull eat shyt keep good control of ur front end and shift ur weight smart look at the shape of the jump and how much u need to manuever ur bike to land and stay in line DO NOT stay over ur ass end or ull end up landing crooked stay in the balance point its pretty much where the footpegs come up when u take off from a jump i look at the face and then directly spot my landing its kinda like a roll just "roll" the bike maybe not the best word for it kinda curve it over the jump i lift up the front end a little through flight and as im spottin my landing i level the bike or adjust my front down if its steeper landing if its a smooth transition just keep the bike level and ull end up going through it smoothly u want to land on ur back tires first just start small sumthing with and easy lip and a smooth landing DONT get comfortable with ur jumps once u start getting in that mode u start fukn up and getting hurt Just Keep your form all the way through the transition and ull be a mx champ in no time have fun bud good luck
if all the plastics match up in the front then then its straight u might be able to get a big peice of steel or sumthin and pry the subframe straighter.
UR needles dont line up? do u mean when u drop the slides in ur carb they dont line up goin down into the hole that leads to ur main? the needles arent in there securely man they slide around and go up and down the only thing holdin it from comin out is a plate that hold the thrott. cable in when u put ur slide in gently with ur finger move it into place carefull with the tips of ur needles if u chip or damage them they will work like shit or not at all.
yah man that looks hella twisted my one frame looks like that and im gonna replace it the other one was just bent at the front where it comes up and i used a Porto jack deal forget what the exact name was but it worked perfect
there are 2 stock ones that go up inside the tank on the gas switch one for the reserve and one for the On there more like screens than thick filters i think if u run a filter it would take away sum of the premix oil
hmm i had the same prob i think it was a pin or sumthin on the side of the crank Jeff at Fast said it gouged the hell outta the inside of my case it sounded kinda like a bearing or sumthin
Dont mean to steal ur thread but i have sum Pro Circuit Plat. with the Factory Sound silencers just like the pipes posted above and was looking for sum decent shape small bore sheerers
Heres a Pic and ther also shown im my Sig.
switch u plug wires around and r u posotive ur slides arent backwards look at the window on the sides of ur carbs when u pull it WOT should be a half circle engraved in the slide
u can go to a hardware store and probly pick up an o ring for it check ur slides ther probbly backwards and if u really want it to start just try pull starting should get her goin
might be ur float height, wrong gaps on the plugs, bad head gasket and check ur fuel on off switch it might be clogged theres filters on them that go up in the tank i have pulled a few out that have been covered in dirt & filth
move the needle clip down right under the middle notch and see what that does and turn ur air screws in about a half turn after u do this reply and if theres still probs wel go from there.
sum PanterA or sum Slayer "raining blood" or that Metallica song i think its Monsters Inc. naw screw that pussy shyt how bout sum N`sync or Britney spears or if ur feelling really hardcore sum *****street Boys Jk sumthing fast and Banshee like lol
Im pretty sure the Cheetah cylinders are Nikasil plated so they cantbe rebored but can be replated cost about 300 bucks. The Cub and the Cheetah make about the same power until u get into the bigger strokes like 7mm and 10mm and so on.
