Everything posted by peterlocal22
ok guys, i sent my clutch cover out to cali to get it polished. i took off the big water pump cover but kept the smaller one that covers the impeller on. when it came back i put in a new billet impeller. i then installed the new gasket for the clutch cover and the polished clutch cover. i torqued all the bolts to specification. my next step was to torque the bolts for the small water pump cover. i then relized i probably shoul have oiled the bearings that are attached to the impeller. should i take the clutch cover off and oil the bearings or should i be ok?? thanks
ASR about the same price but much better quality and they stand by there warrenty. tell mike that peter v o peterlocal22 sent you and he will take care of you. hes a great guy. call asr heres the number 435-577-2266 let me know how it works out
i would go with a -2 or a -1. i ride mostly trails and im going w the -2 just from what ive heard the minus 2 sounds like it reallly hooks up. good luck and let us know what you get.
Ya I got ripped off big time. they quoted me a price of 50 bucks to remove the old tire from the front hipers and to put the two new tires on. I evan had the rings already removed. i needed it done for the following day so i could go riding so i told them i thjought that was steep but go for it. they then call me later that day and tell me the new tires are on but theres a leak because the tires arent sitting right. i say ok fix it, thinking this is their problem because they put the tires on. go to pick them up and they added 30 bucks to fix the leak. they tried for another 50 but finally said 30 would ok. i had the other tires on the hipers for two years no problems. anyways i bring them back home to find out none of the bolts were torqued to specs even though i told them countless time what needed to be toqued. they said ya ya ya we know. I was pissed. HONDA of N Reading in Massachusetts. Ill never go back. thanks for the tip. ill try that next time peter
wasnt sure if this is a good deal ornot but figured i would post it if anyone is looking. [email protected]
i love my hipers there awsome. the only problem i found w them was when i wanted to change tires. i dont have a beedbreaker so i had to bring them into my local shop to get the old tires off and the new ones on. it cost me 80 bucks just to do the the fronts. i was pissed. im going to buy a beadbreaker after that exp. and hopefully i can do it myself. so make sure if you buy them used that you like the tires or you have a beadbreaker. otherwise its going to cost you $$$. good luck and let us know what you get.
looking for a st of ac pro pegs with heel guards. money in hand. please describe and if you have pics send to [email protected] thanks
do it. just becareful if you power wash your bike. dont want to flake it. take some pics after you put it on.
good find
thats what i thought but someone told me you should go back to dual carb setup when you get a woods, mx port? i figured the 2 into 1 would be really sweet w the mx, woods port, ton of low end, but i wasnt positive. thanks
Transmission fluid change?
peterlocal22 replied to Flanagans twin's topic in Banshee Repairs and Mods
thats it buddy, drain out oil, put plug back in and fill. to check the brake fluid the front brakes has a res. on the handlebars and the rear on by your right heel. i would also check your your coolant, greese all zerks, tire pressure, and change plugs. good luck -
Cheap banshee fenders
peterlocal22 replied to Double Deuce's topic in For Sale - Parts & Accessories
oh man just bought some new white one. should have waited and got black. oh well -
if i get a mx port job would a 2 into 1 carb still be better than a dual carb set up? thanks
ive got the trinity 2 into 1 w 35 mm carb and i love it esp on the trails. low end is much better and its so easy to adjust. i have my pilot jet at 50 my maine jet at 185 air screw turned out 2 turns 3rd clip on the needle. im around sea level too, maybe a couple hundred feet up. keep us updated
CPI In-Frames, exhaust collars?
peterlocal22 replied to BansheeBruce's topic in Jetting & Exhaust Forum
i would def. spend the money and buy some pipe clamps. they may not leak now but will probably in the future. ive bought alot of pipe clamps over the years and tm design works pipe collars are in my opinion the best. i think they look the best too. they are alittle more exp. than normal clamps but there well worth the investment. lets us know what you get -
Read down to the very bottom, IT'LL GIVE YOU GOOSEBUMPS!!! You don't want to miss this! ((*_*) ) VERY INTERESTING- 1. The Garden of Eden was in Iraq 2. Mesopotamia, which is now Iraq , was the cradle of civilization! 3. Noah built the ark in Iraq 4. The Tower of Babel was in Iraq 5. Abraham was from Ur, which is in Southern Iraq ! 6. Isaac's wife Rebekah is from Na hor, which is in Iraq ! 7. Jacob met Rachel in Iraq 8. Jonah preached in Nineveh - which is in Iraq 9. Assyria, which is in Iraq, conquered the ten tribes of Israel 10. Amos cried out in Iraq ! 11 Babylon , which is in Iraq , destroyed Jerusalem 12. Daniel was in the lion's den in Iraq ! 13. The three Hebrew children were in the fire in Iraq (Jesus had been in Iraq also as the fourth person in the Fiery Furnace!) 14. Belshazzar, the King of Babylon saw the "writing on the wall" in Iraq 15. Nebuchadnezzar, King of Babylon, carried the Jews captive into Iraq 16. Ezekiel preached in Iraq .. 17. The wise men were from Iraq 18. Peter preached in Iraq . 19. The "Empire of Man" described in Revelation is called Babylon , which was a city in Iraq ! And you have probably seen this one: Israel is the nation most often mentioned in the Bible. But do you know which nation is second? It is Iraq ! However, that is not the name that is used in the Bible. The names used in the Bible are Babylon , Land of Shinar , and Mesopotamia ... The word Mesopotamia means between the two rivers, more exactly between the Tigris And Euphrates Rivers . The name Iraq , means country with deep roots. Indeed Iraq is a country with deep roots and is a very significant country in the Bible. No other nation, except Israel , has more history and prophecy associated With it than Iraq And also, This is something to think about: Since America is typically represented by an eagle. Saddam should have read up on his Muslim passages ... The following verse is from the Koran, (the Islamic Bible) Koran ( 9:11 ) - For it is written that a son of Arabia would awaken a fearsome Eagle.. The wrath of the Eagle would be felt throughout the lands of Allah and lo, while some of the people trembled in despair still more rejoiced; for the wrath of the Eagle cleansed the lands of Allah; And there was peace. (Note the verse number!) Hmmmmmmm?!
you from tenesee because your the only ten i see. nice shoes, wanna fuck
welcome bro. id love to see some pics if you have any? thanks
i was in a bit of a rush so i didnt really get in there. but theres a long line on each of the carbs. Infact its the longest line(s) out of all of them. that line goes right out to the bottom of the bike. if you have a belly skid plate on your bike it goes beyond the sid behind the last frame rail that holds the motor. so if you look under a bike w a belly skid its the only two lines you will see. im bad at explaining stuff sorry. if this doesnt make sense ican take a pic tomorrow? thanks for your speeedy replies guys.
whats up guys, well i noticed my bros banshee is leaking gas. the carbs have several differnet plastic tube lines coming from them the two that are the longest lines and are located closest to the swing arm. well one or maybe both of those are leaking gas. i shut the gas line to off at the tank and it obviously stopped but anyone know what this is from? never had this problem before. thanks
ya she does, and there all hot!!! right ty?
id go w the 450
your bike is real clean looking and starts right up. i drove it around the yard and it moves. im pumped you made the switch your going to love it. welcome to the hq. this site is great for all banshee owners. theres alot of people on here that can help you with any of your banshee questions.
