peterlocal22
Everything posted by peterlocal22
  1. anyone know how to get in touch with mxbanshee? i know he hasnt been around in a while
  2. hahahaha, im with xxblessedwithdeathxx. when i read what he said, it really made me smile because hes right to the point. nicely said bro
  3. thanks ill waite 24 hrs
  4. anyone know the time it takes for primer to cure? hours, minutes? thanks
  5. had alot of scrapes on the bottom of my bros banshee frame and i wanted to get it taken care of before winter to prevent rusting when we go riding in the next couple months. so i did a light sanding and then applied a couple coats of rustolium spray primer. how long do i have to waite after this to apply final two coats of rustolium spray paint? thanks peter oh ya the back of the can had no info on this. unless i missed it.
  6. ya maybe the high bend and the 2 inch risers would be too high although it les than an inch difference?
  7. welcome to the addiction
  8. anyone know what a stock banshee handlebar height is? thanks
  9. anyone know what a stock banshee handlebar height is? thanks
  10. im thinking of getting the quad high bend flexx bars with 2 inch risers but wasnt sure if this would be too high. i think the flexx bar highs are 116 mm then the 2 inch risers? theres also the low bend which i think are 92 mm.
  11. whats up everyone, Im 5 ft 10 inch tall. love riding the woods and i would like to start getting into xc racing. Im currently in the marcket for new handlebars and im wondering what I should go with. High bend or a low bend. Also are risers important? thanks for any help, im in the dark on this one.
  12. changed out the tires because the old ones were done. new ones were balanced and the ride is much better. however i still feel a slight vibration in the seat but its very small. thanks everyone for your help.
  13. also do drive ahfts go after 50000 miles?
  14. any idea how much that might cost? thanks
  15. great how much is it to replace a drive shaft?
  16. i checked the back and there clean. when i really lay on the gas from 40 to 80 you dont feel the vibration, but when i slowely go from 40 to 80 you will feel the shake at 55 to 65 then when i slow down same thing shakes at 55 to 65? weird. ill get the wheels checked tomorrow. wee can i get the road force balance? thanks
  17. if it was the belt or tie rods wouldnt the shaking continue evan after 65 mph?
  18. whats up everyone. i have a 2003 chevy silverado. 50,000 miles on it. drives great except for between the speends of 55 and 65 mph. it shakes. anything below 55 and its fine, anyt thing over 65 and its fine, anything between 55 and 65 and it shakes? anyone exp. this w their truck? any one have any idea what it might be? thanks
  19. my temps were around 180 when riding last weekend pretty hard. weather was around 70 degreees.
  20. ya i would go with works too but i would contact works direct. i talked to them about 2 months ago and they were offering 10% off on there already low prices. let us know how it turns out.
  21. 195-210 is high unless you were just putting around the i thought that would be the ave temp. if you were really moving and getting some good airflow through the radiator them that temp would be high.
  22. yes refer to front-end alignment and you will beable to dial it in. I have a question for you, is the inner lip hitting the a arm when the front end is on the ground or do you have it on blocks? As far as compensating for the zps when just sitting the only thing i think you can do is to adjsut the shock to the firmest level it can go on. I had this same problem and even when i crancked up the dial on the ressie it still had some sag which brought me too low. so i then bought bigger tires for the front to bring me up a couple inches. got some 23 inch. I finally got rid of the shocks because of the zps. just too low for my riding, trails.
  23. kenda klaws 23 inch for front the reason is because this will give you great riding height for the woods and trails. i run them and there awsome
  24. i were your going w this greg, lol
