Take off the clutch cover, then the 6 bolts that hold on the pressure plate and the rod should come out. Honestly you should consider buying a manual (for all torque specs etc...)
I have a bunch of banshee parts on Ebay, check my other auctions and feel free to make offers
http://cm.ebay.com/cm/ck/1065-29296-2357-0...riptionANDimage
http://cm.ebay.com/cm/ck/1065-29296-2357-0...48782242&lk=URL
Item #4648773361
CPI's gone
Sounds like you might have a leaking head, some times (even with new parts) the head surface isn't flat and you have to run it on a surface block. Or it could be one of your o-rings is pinched
The hinson pressure plate is a little thicker, which means the lock up arms will swing a little less. I used one on my 10 mill and didn't have any problems. What kind of clutch are you using?
Well, when you first fill a side cover the oil level will seem high until you start it or let it sit for a while. then it will even out. If you're sucking oil into the crank case it usually has a pretty dramatic affect on the motor. Also just a suggestion I run 2 quarts on my lock up cover
Get rid of those t6's if you're going to use them on a ported motor, I'd get your crank trued and welded with a new bearing or bearings, then get a 68mm bore cub top end. And for pipes, shearer or cpi. Best bang for your buck.
If you look @ the pic you have the white plastic cover for your shift drum, to the left of it there's a hole with a aluminum then to the right if it there's a hole with a plug missing, you need that plug
OK, from the pic it looks like the shift fork guide plug is missing, if your cases are broke, you need to have them welded to hold up for the long term
