joker149999
Everything posted by joker149999
  1. ok answer me this then if i have a blowen seal or a cracked case why does only one cylinder cut out off idle? it's a open crank case there for it should affect both cylinders. i guess i just don't understand
  2. I have 2001 bike, i have removed the tor's i have k&n airfilters with no air boxes i run delta 4 race reeds a high compression head, ported and polished, long rod crank, .80 thousands over piston's and t-5 pipes, and here is my question i run my bike 32 to 1. It misses on the left cylinder above a high idle. I've checked and cleaned the carbs, swaped the plug wiresand plugs, checked the reeds for air leaks and it seems to have good compession on both sides and it runs the same. Does anyone have any suggestions? Thanks for the help
  3. yeah i can find the seat foam and cover but not the damn frame unless i wanna spend 200 dollars from the dealer ship...........
  4. i agree you will be safe. just keep the filter's clean and stay away from water
  5. the bike for 30
  6. no it's a kdx 80 they only made them for a few year's, and i need a seat, it can be used, i bought it for like 30 buck s and everything is sweet except the damn seat at kawaski they want 200 dollars for a seat
  7. I just bought a little 1988 kdx 80 and i was wondering if you guy's know were too get any after market parts for it?
  8. i run with no air box, buti have outerware's and clean my filter's all the time. more air more power
  9. you won't gain a whole bunch from boring them out so. i agree just hone them out if possible or just go .20 thousand's
  10. I totally agree, replace it
  11. i wonder if maybe your efi box is bad then
  12. i bet it's either sucking air at your reeds or you have not unhooked your throttle over ride yet cause that will keep it from idling as well
  13. i was sucking air on mine from the boot a while ago and both cylinder's were firing just a lot of back firing and it would not idle. but i would check your carbs for sure
  14. If ya wanna stay low with the money deal, i would just have the head milled down that way you don't have too spend money on a new head plus ya will get a higher compression. but if i were you i would replace the water pump shaft with a high flow one piece one and get rid of the stock one any way's that way you know that your pushing the coolant where it needs too go and no worry's of the water pump fins coming off the shaft like the stock one can
  15. if it's cracked i would say your sucking air, i would replace the boot, one way too find out is run it and then spray a little bit of starting fulid on the boot and if it spike's the rpm or raise it, it has a hole. but too me it sounds like you might not be getting fuel too that cylinder i would check your carb out if it were me
  16. i have a 2000 Banshee, i got rid of the tors on it and put carb tops on, but i still can't get it too idle with them idle screw's i have tried adjusting the cable the idle screw's and can't seem too get it right any idea's? it has not idled since i put them carb tops on...........
  17. it has nothing too do with the fuel, i would say one possibilty is that guy may have done a ratical port job and opened it up way too much
  18. i doubt it's a head gasket, if it's leaking out of the breather then i would probally say your filling your over flow tank too full your only suppossed too put a little bit of coolant in the over flow so it's getting hott and the coolant has no where too go so it just pushes it out so it won't blow a coolant line
  19. i would say go like .40 or .80 some where in there
  20. i dunno i perfer to run with no air box at all i get a lot more air flow but i run k&n filter's and pre filter screens so i don't pick nothing up, the only bad thing is ya have too stay out of the water,
  21. i would say it's the lower base gasket leaking but that's just my two cent's
  22. i have a stock rear sprocket and a changed my front sprocket from stock too a 13 and had too take a link out of it, but other then that it's fine, but you do lose top end, but i don't ever ride in sixth gear much so it does not matter
  23. I run 15/40 Delo in my transmission and it does fine
  24. oh yeah and you could re gear the bike with new sprockets
  25. I agree get a good porting job done and if so take the air box's off so the bike can breath better but ya better put some pre filter's on them if ya do, and also can some v-force racing reeds
