Toybreaker
    7
Everything posted by Toybreaker
  1. Guess not? Ok.... Anyone interested in a build thread for the transmission on here? Sent from my iPhone using Tapatalk
  2. Whenever I have suggested meeting at a police barracks/station and the seller does not agree I walk. Not willing to meet at a police station means you are shady.....
  3. yes the warrior wheels will fit
  4. Payment Plan is a stand up seller, I am sure he is negotiable and if you can't come to an amicable agreement go to that website and buy them.
  5. find some fuel safe dye and make it part of the routine for mixing your gas.....
  6. 1) There are rebuild kits for the kicker.... quick fixes on that do not last. 2) Bleed the rear brake (replace all the fluid, completely) think about a steel braided line too. 3) Normal, trim the fender back a bit from the pipe to stop any more damage to the fenders. 4) smaller tires make it easier to accelerate. you can put your wifes warrior wheels on the shee, take it for a ride and see how much worse the performance is....
  7. Dude, you have an air leak... how many times are you going to open a thread about the same thing. running with the choke on means it needs more fuel..... Insert other media Do a leak down test, find the leak, fix the leak, do a plug chop, report back
  8. Quadzilla is a better chassis for this swap. Seen a lot of different versions, Raptor, Honda, suzuki, banshee.... Turbo busa in the zilla was my favorite.... But a built 4mm or 7mm will out perform the R1. 300 lbs lighter and 80-110 hp on pump gas. Properly built banshee engine will last for YEARS. My wifes 96 is still on the 64.25mm bore from 1998. Runs mint!
  9. Sully? what were you running on yours?
  10. carb issue for sure, check the tube between the carbs is not cracked and seated properly. If that is it, are the slides in the correct carb? swapped side to side is BAD have you changed the pilot to a 27.5? if not, do that, and while you have the carbs off put them in a can of carb dip overnight. Pull them and clean every orifice with brake cleaner and blow out everything with compressed air. I would run torch tip cleaners through main and pilot jets, just as an SOP thing for when I go through carbs... Once assembled and back on the bike LIGHTLY seat the air screws, then turn them out 1.5 turns as a baseline. eyeball the "sync" before you assemble the rest of the intake, tank, fuel lines and again at this point I would remove the petcock and flush out the tank, clean the screen filter on the petcock and put it back together.... new fuel lines and filter(s) drop tank on, prime fuel system and fire it up to see if it is fixed.... It idles and revs out good without load? Final assemble and take it for a putt....
  11. Change one thing at a time.... write down any changes corresponding to the "fix" sometimes 1 thing is fucky, most times it is multiple things causing the hard start/rough running/stall.... Keep It Simple Stupid KISS principle for troubleshooting and repairs...
  12. buy new boots, a vacuum leak will pop your pistons.
  13. Ok Friend's son-in-law dumped his F450 in the friends yard. Needs the trans rebuilt. Cab and chassis, longer than long bed, single cab. v-10 ZF-6 trans.... the output shaft into the transfer case has no splines left. Parts to "rebuild" it are $400 give or take. anyone here ever gotten into one of these HD transmissions? Done muncie, saginaw, c4, turbo 350, whatever a 96 S-10 has for a 5 speed and 4R70W's....
  14. https://connecticut.hibid.com/catalog/204599/spring-firearms-auction/
  15. List all the things you think are possibly the problem. Literally #1 #2 #3 etc Go about isolating EACH thing ONLY, make a change/swap the part. see if it changes... make notes on your list. It might be 1 thing, it could be 3 grouping together to get it all jacked up.... Start with the gapped idea Hopped up said previously.
  16. Ok depending on elevation and temp........ 300 main 27.5 pilot and get an aftermarket set of needles and set it in the middle.... do a plug chop and go from there.
  17. Oh hell no, find the closest PD station to the seller and arrange to meet there for the hand over of the money for the bike and paperwork.... get it checked then. If he refuses, then its hot. Or he has warrants.....
  18. definitely get more opinions. More info is always better.
  19. definitely too small. kenda K547 or quarter midget tires are a better option. get your diameter (rollout) up, can get a higher top speed and not be on the rev limiter by 300 feet....
  20. 18" diameter is tiny, smaller tire = more rpms..... you will top out at what? 80 mph? doing 300 ft? 1/8 mile?
  21. the stuff that does not detonate
  22. holy fuck dude! once was enough...
  23. Lots of options, use one of the sponsored vendors on the website here.
  24. Ok read this, and next read this again After you understand this buy 260-320 mains (if you have the jets great) 27.5-32.5 pilots Get a longer aftermarket needle set (i like the toomey needles) I have a similar set up to yours, My bike likes 280 main 27.5 pilot with the needle 2 slots from the tip. Buy 10 sets of plugs. change jets to your "baseline" and do a plug chop. post pictures of the resulting plug for review (and the inevitable peanut gallery comments)
