wood
Everything posted by wood
  1. what's up no norcal riders out there.
  2. going to stoney on the 21-23 anybody up that way.
  3. i run the t6's woods port .20 over cool head +4 timing v3's k&n and it pulls real hard i ride tight woods trails and some wide open areas.as for in the tight stuff i think the power is unreal,dont know if alot more power would help but with my mods the t6's work great.
  4. i had the same problem,i think the slides are hanging up,i was getting alot of water in my air box and i have a k&n with an outerwear,smooth out your carbs,duck tape around your air box to keep water out,check all of the boots,from the air box to the carbs,and the carbs to the intake,that air filer has to stay dry.
  5. i will talk to the guys this weekend and get back to you next week.
  6. i work at my local hd shop on the weekends see if you can narrow it down a little more and i will ask some of the guys what it might be.
  7. are the wheels bouncing when you are riding,how much air pressure do you have in them.
  8. ya lot of rock and other things,thanks.
  9. i was thinking of powder coating my rims,wanted to know how well they will hold up,mostly ride creek bed,forrest,and open dirt roads.
  10. might want to carry a tire plug kit and a small hand pump.
  11. you should have 4 gaskets they go in both places.
  12. i bought one and though it was crap,if you pick one up you better buy some extra velcro for the sides,it only has velcro on the front and back.
  13. wood
    vf3
    thanks.
  14. wood
    vf3
    yes they were bad,how do i get the inside pedals out.
  15. your mods say that you have pipes and jets so you should already have your air box lid off,all of the other mods will help alot but if you dont have a ton of money maybe start with a k&n,or new rear tires,that should help.
  16. wood
    vf3
    thanks,i will check them this weekend.
  17. i wanted to know if your reed pedals can go bad,or should they last for a long time,is there a way to know if they are bad.
  18. the only problem is that if you run no air box lid so that the air box lid hold the top of the filter to the air box the bottom of the filter will sit in the grove but the top is loose.
  19. buy a k&n with the adapter plate.i had the same problem with the foam filter.
  20. tried some clr on my t6s,how long do you let the clr sit and what are you using to wipe them clean.i am tring to clean the front part of my pipes,right were they come off of the motor.
  21. i bought mine of toomey the kit came with evrything you need,i all so put on the 1/4 twist throttle.
  22. thats what i did and no problems since then.
  23. do you have a twist throttle,i had the same problem,might have to smooth your sildes,try and losen the cap on top of the carbs,and if you have a twist make sure you dont push the throttle to the end of the bars because the grip will hang up on the bars.
  24. call toomey they should have what you need 805-239-8870.
  25. on the handle bar clamps how does that work,looks like they go on the rad. hose,and what temp do most banshees run at 180,200 because i dont know.
