Animalman294
Everything posted by Animalman294
  1. Title her in Cali, say it isn't so. Well if its a way for the state to get more of my money they have a law for it................. ::
  2. Ya, I bet it can take a banshee...............but not after you put the rear tires back on the shee. It has never been raced, even though I spank 440's, what a dillweed..................
  3. I wish something would work out in my favor for once. I always said that if it weren't for shitty luck I wouldn't have any............... ::
  4. Have fun wish I could make it................
  5. Or Craig's list...............
  6. I remember a while back that there were a couple of guys that did the Reno to Vegas race and held there own pretty good.................
  7. You might try motosport wherehouse...........
  8. Wannashee joined like yesterday at 9:41 PM and only has 41 posts (all on this thread, I'm sure) and went right to work insulting one of our member's and his girl. This guy reminds me of that one guy that started crap before, some of you may remember the name "night", just without the stupid language......... :shoothead:
  9. Man, this is a huge ass thread and it just started. I think something similar to this happened a while back and all the avatar's were changed and the sig's were modified to appease a couple of people. For those of you who posted your lovely ladies, I think you all had nice lookin' ladies and other's were just plain hot. But all it takes is one bad apple and the pie is ruined.......... ::
  10. Stick with what works and its not Alba............
  11. You should be able to easily retap it, but then once the cooling system is ran a while you may wnat to drain it again to see if you can flush out any shavings from the retapping...............
  12. what are you talkin' about, its a honda............... :yelrotflmao: :yelrotflmao: :yelrotflmao:
  13. It's about 70 degrees, and one plug is lean (snow white) and the other one is dead on or chocolate brown (1/2 to 3/4 of the electrode). I'm not sure why this is happening yet. Also not sure if its an electrical or carb related problem either. So I think that I need to check my carb on the right for debris and then move on to the electrical issue. I have always had problems with one plug looking different than the other...........
  14. I run Motul.............
  15. Are you sure you bled the lines and the caliper on the side that is not grabbing good. You may still have air on that side and wont allow it to grab as hard as the other..........
  16. I think his original bragging about the 70hp may be within range, if its a cubby, but with 34's and depending on pipes, domes, timing..........
  17. Some of those are pretty funny................ :yelrotflmao: :yelrotflmao: :yelrotflmao:
  18. Ya, I'm runnin' a 52 pilot and a 168 main at 1000' in northern cali..............
  19. I got mine from Jeff at FAST. He sells it by the foot, so just tell him what length of swinger you have and he'll hook you up............
  20. HAve you modified the intake at all. When I first put my cubby in I had to modify the filter's by moving them back in the bike with extension tubes and my plugs looked like your upper right and the other the bottom left. Now I was told that my modified tubes between the carbs and the filter's (to clear the exhaust so it wouldn't burn the outerwears) I was infact introducing vortex's inside the carbs and it messed up my plug chops. Removed the tubes and hooked right onto the carbs and problem solved.............
  21. Well it sounds like you tried the PTR's and the Toomey's, and if you have the CPI's in the mail, then you should be able to figure out which ones perform the best on your motor without dyno sheet's. Because all three pipes will have to be put on the same motor in order to get accurate results so that they have the same mods.............
  22. Try the needle in the middle clip, because the needle adjusts like 1/4 throttle through 3/4, and main jet is like from 1/2 to full throttle.................
  23. Ya, and I've actually seen the after effects of a guy who put the slides in the opposite carb and when it wouldn't go, yes dillweed used a hammer and couldn't figure out why the slides wouldn't move up and down. So my dad bought it from him for $2500 because he couldn't get it to run and it was worth at the time $4000................. Moral of the story: know what you are doing before you try to fix something, and never use a hammer when you can slide it in with your finger............... Man that sounds bad :yelrotflmao: :yelrotflmao: :yelrotflmao:
  24. Ya, but I think every hobby is and none of them are any cheaper trust me. Every hobby that I have ever done cost me a lot of money...........
  25. Ya, tear it up Tyler..............
