Mod Banshee
Everything posted by Mod Banshee
  1. I just got back from a 300ft Drag race I raced Trail Mod today and Won my Class. And then this guy that raced Pro Mod came up to me with his LRD 330R and wanted to race me. And it was a Close race we were even off the start and then he would pull 1/2 bike on me and then I would pass him and win by 1/2 Bike. I want to get my Flywheel Lightening who should I send it to?
  2. The Banshee will win with no Problem. But if it was a MX Track the 250R would kill the shee.
  3. Well I was suppose to race a Predator tonight. The guy said let me ride your Shee First and I said ok. He did about 4 runs and said I will be back with the Predator this was at 7:00 and now it is 9:10. He never came back
  4. Two of my Buddys Lined up today in a 300ft drag race. The Grizzly got the Holeshot and then the Z would pass the Grizzly at 200ft and only win by 1/2 quad.
  5. Ok we drag raced today and I beat him by 2-3 Quads.
  6. My buddy has a Stock Z400 and he his running 6.5s in 300FT and he says he will kill My shee and my Shee is running 5.4s in 300FT. How much will I beat him By?
  7. He was back over the other day and it was dry and he can a 7.31 on the same drag Strip.
  8. Ok I got my Time down to 5.4s that is with the stock gearing. I will be trying a 13 & 15 Tooth this weekend. And I will be Drag racing in the Trail Mod Class on August 15
  9. I know my shee spins from 1st-4th
  10. It is on Dirt with razr2 (20X11X9) rears and razr (21X7X10 fronts & Axis Front shocks and works Ultraceoss rear shock. And I weigh 279LBS
  11. Mod Banshee
    300FT
    What time & Speed are you running in 300f. Time-5.5 Speed 54.5 Mods FMF Fatty Pipes FMF Power Core 2s Race Logic Porting Vitos Power Pistons Cool Head w/21cc Doms 28mm Flat Side Carbs Boost Bottle V-Vorce Delta 2 Vitos Degree key Pro Flow Intake 6 Filtered air vents Team Alba Clutch Kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate Is that a good Time & Speed for my shee with these Mods
  12. Well I had a Set of works Triple Rate front shocks on my Shee and I did like them alot. But I wanted a better set of front Shocks so I want with Axis Front and I keeped my Works Ultracross rear shock. But The only other Shocks I like is PEP.
  13. I know this is a Banshee Forum. But my Buddy on his 03 Stock blaster ran the 300ft in 8.13 on Wet grass. Is this a good time for a Stock Blaster?
  14. You can get the Cool Head from Rocky Mountain for $ 255.99 and that is with 22 cc domes
  15. I have the Pro Design and I like it alot
  16. I would say a Cool Head with 21cc doms or a set of Razr 2 rear tires and a good porting
  17. I need a good set up for a 300ft Drag race? Here is my set up I have now FMF Fatty Pipes FMF Power Core 2s Cool Head with 21cc doms Vitos Power Pistons Race Logic Porting 28mm Flat Side Carbs V-Force Delta 2 Boost Bottle Team Alba Clutch Kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate Vitos Degree key Pro Flow Intake 6 Filtered Air Vents 15/41 Gearing
  18. Well I had my Dad help me do a Compression check today and it is 125psi Now. I had a hard time doing it my self so that is why I think I got 105 Befor. And I have 21 CC doms.
  19. I am going to try the 19cc domes
  20. We just put a new Top end in it. And that was when I did a Compression reading and got 105PSI
  21. I do not Know what elevation we are at. But I live in NY. And No my Crank is not welded. But Next summer I think I will put in a wiseco Hot rod Crank from Nacs for $379.95
  22. I have FMF Fatty Pipes & Power Core 2 Cool Head with 21 cc Domes Race Logic Sport Porting Vitos Power Pistons 28MM Flat Side Carbs V-Force Delta 2 Boost Bottle Vitos Degree Key Pro Flow Intake System 6 Filtered Air Vents Team Alba Clutch Kit Hinson Clutch Basket Hinson Pressure plate Hinson Cushions And My Compression is 105 so I would like to go to a smaller Dome. But I do not know how smaller I can go and still run Pump Gas
  23. I will only run Vitos Pistons in my Shee.
  24. I have the Team Alba Clutch Kit is is the Clutch that is in the R1 Sportbike with a Hinson Clutch Basket and Hinson Pressure Plate and Hinson Cushions. I like this set up alot but it will cost $600 for this clutch set up.
  25. I have the WB Mikuni 28mm Flat side Carburetors. I am In NY I do not Know what Elevation we are at. I am running 270 Main jets and the air is set at 2.25 or 2.5 turns out.
