Mod Banshee
Everything posted by Mod Banshee
  1. I have a set of FMF Fatty Pipes and Power Core 2 Silencers I will sell you for $200. They are in very Good Shape.
  2. I have a set I will sell you for $50 Plus shipping.
  3. What is the best Pipes to run with this Kit? FMF Fattys LRD T5 CPI I have the FMF Fatty Pipes Now. And what gearing should I run with this kit? I trail ride and Drag race in 300ft. Jim says to run 16/39
  4. with 20x11x9 Razr 2s
  5. What will the top speed of my shee. It has Passion 12 Port Stroker kit 33PWK's Boss Intake Cool Head w/21cc doms FMF Fatty Pipes & Power Core 2s V-Force Delta 2s Team Alba Clutch Kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate Lightened FlyWheel Vitos Degree Key Pro Flow Intake 6 Filtered Air Vents 16 tooth Front Spracket 39 tooth Rear Spracket
  6. I have a set of Razr 2s on my Shee and all it does it spin from 1st to 4th. I think I will try a pair of Black Waters next summer.
  7. Send it to Jim at passion Racing
  8. Can someone help me out? I want one that will hold up and does not weight allot.
  9. What is better Aluminum or Steel or nacs Aluminum Extra Light Version?
  10. Ok I will do that.
  11. I want to get a set off CPIs. But the Passion 12 Stroker kit and the 33 PWK'S and the boss intake and a different cable set up is go to cost me all most $2000.
  12. I think That is what I am getting. The Solid billett Manifolds are coming from Jim and they are $150 and the Boss intake is $150
  13. And the rest of my Mods are. Cool Head w/21cc doms FMF Fatty pipes Power Core 2s V-Force Delta 2s Boost Bottle Team Alba Clutch Kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate Lightened Flywheel Vitos Degree key Pro Flow intake 6 Filtered air vents 15/41 Gearing
  14. OK here is what I am getting. Passion 12 Port Stroker Kit Solid Billett Manifolds 33mm PWK'S And the rest of my Mods are Cool Head w/21cc Doms FMF Fatty Pipes Power Core 2s V-Force Delta 2s Boost Bottle Team Alba Clutch Kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate Lightened Flywheel Vitos Degree key pro flow intake 6 filtered air vents 15/41 gearing
  15. Ok I am getting the Passion 12 port Stroker Kit with Solid Billett Manifolds and pwk's 33mm Carbs. What is Lectrons? And were can I find it?
  16. I talked to jim today and he say to run 33PWK Crabs
  17. Can any one help me out? I was thinking about a PWK 33MM Carbs.
  18. I am going to be getting the passion 12 Port Stroker Kit. What size Carbs should I get? Now I have 28mm Flat Side carbs.
  19. Ok I just got done talking to Jim a Passion. Do any of you Know how much he will bore it out? Over the Winter I am going to get the 12 Port Stroker Kit for my Banshee. I cant wait to ride it with all of my other mods to see what this this will do.
  20. Can the Passion 12 port stroker Kit still be done because I have my Cylinders ported by Race Loigc sport Port?
  21. Ok Now that I think about It I think I will get the Passion 12 Port Stroker Kit. Do I get new Cylinders with this kit and do they come in different Colors? I see on there web Page they have Pics with Red,Yellow And pink Cylinders.
  22. The stroker Crank is the Long Rod 4mm stroker Crank? And can I get that from Passion?
  23. I dont want to run a Stroker crank.
  24. Ok over the winter I want to send my Cylinders to them for the Traditional Full Drag port or the 12 port Porting. Now My Question to you is what one should I get? I do alot of trail riding and alot of Drag Racing. And will it work with a Wiseco Crank? Or will I have to get a Stock Crank? And I also will have Passion racing weld the Crank for me.
  25. Ok I want to have it bored out to a 370. Now who should I send it to. And Should I also have it reported. Now it is ported by Race Logic Sprot port.
