Mod Banshee
Everything posted by Mod Banshee
  1. O No I had the same thing happen to my shee you have to spilt the Crank Case. The Rod is probably mushroomed against the Clutch push lever.
  2. Mod Banshee
    This tarck was a B*tch to figure out. There was only 1 Quad that ran 4s and it had a 1000 Snowmobile Motor in it and it also had snowmobile Studs in the Tires and a set of Drag Pipes.
  3. Mod Banshee
    There was 2 Fully Drag banshee there that ran 5.073 and the Other ran 5.484. And they did not even have quad motors in them one had a 1200cc sport Bike Motor with NOS and the other had a 1000cc Snowmobile Motor with NOS.
  4. Mod Banshee
    Well I am not sure how much HP my shee has But the people I have talked to told me it should be about 70HP. And I Drag Raced a Shee with clamp on K&N air filters and HoleShot Rear tires and I won in 300 ft. He is about 125 LBS give or Take and I am 270-280 and his best time is 7.335 and Mine is 6.033. I now My shee will run faster then that. But on that track I would spin from 1st all the way to Top of 5th. And I cross the 300ft Line in top of 5th. But I will be going back in septerber with Self Tapping screws in my rear Tires and a Lightened FlyWheel.
  5. I have FMF Fattys & power core 2s on my Banshee and I love them. They have Great power. But if I was to get a new set of Pipes I would go with the FMF SST or the LRD Super Adjustable Pipe.
  6. Mod Banshee
    It will run lower then 6.033 in 300ft no one on that track was hooking up. when I am on a track that I can hook up on it will run 5.4s or lower.
  7. Mod Banshee
    I run 14/41 gearing when I drag race. I start off in first and I cross in Top of 5th. And this is in 300FT. I race in Tral Mod and I won my first race last week end. and I have 70hp. If you want You can PM me and I will help you out more.
  8. Ok at are Fair last sunday there was drag racing and the fastest time was on a Fully Mod Drag banshee he ran 4.2s in 300ft. And he told me he shut it done at 150-200 ft and his speed was 71.4 MPH. And I won the Trail mod class on my Banshee with a time of 6.033 with a speed of 50 MPH. I had alot of problems trying to get it to hook up. But I am going back to the same track in September with a Lightened Flywheel and self tapping screws in my Rear tires.
  9. I am getting the Stroker plate from Vitos. And I wiseco told me My porting would be Fine. and I am going to run the 795 Pistons.
  10. will Part #w6093 Top end gasket kit work with a Cool Head?
  11. The Racer's Choice Long rod Piston kit is a 64.5 and STD is 64. If I want to run the Racer's Choice long Rod Piston kit do I have to have it bored?
  12. OK Thanks I will try that.
  13. 5th Yes it would hook to good and bog so I had to start in first
  14. Yes I have ran the Bike before 14/41 works good but I cant start in 2. I drag Raced Last weekend in trail mod and won my class
  15. On some tracks it will lift and on some it wont Lift it is all according to what the track is made of. I want to cross in 5th. No I do not want to run Struts right now Because I still Trail ride.
  16. Ok I went to Wisceo web page and it does not say any thing about a Stroker plate. And I Called Wisceo and they told me they did not Know any thing about a Stroker plate for the Long Rod 4mm Stroker Crank.
  17. Ok I am 270LBs and I still have the stock Chassis with With Work Ultacross rear Shock and Custom Axis Front shocks and Razr 2 rear Tires (20/11/9) with self tapping screws in them and Razr Front tires 21/7/10. And I start off in first or Second gear.
  18. FMF Fatty Pipes FMF Power Core 2s Cool Head w/21cc doms Race Logic Porting 28mm Flat side Crabs Vitos Power pistons V-Force Delta 2s Boost Boostle Team Alba Clutch kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate Vitos Trail Degree key Lightened FlyWheel Pro Flow intake 6 filtered air vents
  19. What is good gearing in 300ft? Now I have 14/41 on my shee.
  20. Does the Wiseco +4 Stroker crank come with a Stroker Plate?
  21. No it does not need to be Bored. But we were talking about getting it bored 40 over when we have the Stroker crank put in. And should I run the Vitos Drag Degree key? I have the Vitos Tail key in my shee Now. I am trying to build a Drag/Trail Bike. Here is the Mods I have Now FMF Fatty Pipes FMF Power Core 2s Cool Head w/21cc doms Race Loigc Porting Vitos Power Pistons 28mm Flat Side carbs Vitos Trail Degree key V-Force Delta 2 Boost Bottle Team Alba Clutch kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate Lightened Flywheel Pro Flow intake 6 filtered air vents 14/41 Gearing
  22. Over The winter I am going to put in a +4 Stroker Crank in my Shee. And I was wondering if I should get it bored 40 Over? And should I get the Vitos Crank or the Wiseco Crank?
  23. I am going to send it to Boonman.
  24. Did you get my PM? I want you to lighten my Flywheel I will send it to you in a Day or Two.
  25. I want to have my flywheel Lightened but dont know how to send it too. I was told to send it to boonman and then somone told me to send it to Holywood.
