FORMULASPEED
Everything posted by FORMULASPEED
  1. My ass thats an empty bottle for a hundo. Who the hells he kidding. Ketimine
  2. I have an 87 aside from the j arms there is less gussets around the subframe, frame connection area. My 90 has them though, and where new shees mount the foot guards I dont have these mounts on either 2. The rear sprocket hub has four arms instead of six. the front brake calipers are larger. The spindals are different for caliper mounting. There is no brake switch at the pedal. The electrical harness is different plug and wire wise, and this rev limiter I hear about dont exist, I dont think. Well Its never cut out on me in any gear, maybe in neutral. and the gearing and tire like he said. thats all I noticed. edit acc to clymers 87-89 = 401 90 = 408 must be gusset and smaller calip /spindals 91 += 410 add some saller hubs newer style calips/spindals small tires get rid of coolant bottle. Cut off the mounts w/ rubber dampner for the stock exhaust and the torrs box mount. Id guessin 30 lbs lighter more or less.
  3. 7.4 lbs on the clutch spring bolts.
  4. username is Passionre here is a link to a post link
  5. I seperated my crank at 160 psi. Compression or porting calls for a welded crank. Or you will have a ticking time bomb between your legs.
  6. I wasnt tryin to blow your shit up Infidel!!!!!! i didnt think youd be that high with no porting. Banchetta is the jetting man so listen to him. I would like to know what jets you end up using. Ive noticed people in other states are jetted way different than here in MI from just pipes to a decent amount of mods.
  7. 310 might be to high Im thinking. but maybe not with your stroker or is it a longrod crank. If it a stroker it should be port timed. Were you at in MI thats 70+ degrees?
  8. Im in michigan also. Try runnin 310 mains 30 pilots. The 30s might be rich cause of the humidity in this shitty state, if so try 1 pilot smaller. I use a 15/42 gearing.. Pulls just fine.
  9. Hell no . Use gaskets.
  10. where the cases seam together is the point of alignment. Dont take it in ever
  11. The oring on what the pipes or the intake? were is you jetting at now?
  12. I took mine off to. Havent had to add anyantifreeze to it.
  13. Some on posted this link to free pic hosting in another post And it works. I was loading pics in 2 min real easy to use also. AAA+++
  14. Are you running the Orings for that intake? If so that maybe the problem. When I had mine I used regular intake gaskets. Then I had rebuilt my motor and onlly had one set of gaskets. so I used those and the orings and less than1 hr on my new motor it blew up on the left side. . Yes my intakes where tight. So I blamed the problem on them. Put new piston in it, put my stock intakes back on and carbs. No problems yet. Infact I like it better The trinity seemed to run flat at wot. And I diddnt see that much bottomend loss. When I put it on I put other stuff on to so I didnt know how much it helped. Until I went back stock, and I like the duals. The water sux wit stock carbs so Ill be going to flatslide 28s soon. Hope this helps.
  15. Figured it out. You have to save the item, then put in the location. Before I was able just cut an paste the URL in properties from a web site.
  16. Link to keihin here is BenBBs unofficial jetting page jetting
  17. Wow! !!!! Its even a 2 stroke and it runs on diesal. bet you it takes a tanker truck and 8 barrels of oil to make a half tank. I got to see what that goes in.
  18. Kiehin goes up to a 230 on that carb. In the winter it will suck cause you cant get no bigger. You can always install a power jet or go to a 36mm
  19. I can load them to comcast but cant get them to appear here. What do I need to cut out of the http ?
  20. What site do you guys use now since imgestation dont work? I cant get my comcast to work either? Does anyone else use comcast for pics??????
  21. How well do they operate with + 2 a arms? Is it worth it with the +2s? If this has been discussed can I get a link?
  22. I use adware. It works great ,after useing it I no longer got pop ups, popin up every 2 seconds. I run the scan 1or 2 a week. The firt time I used it I had 300 objects.
  23. Oh Then you give him 600 I know what the currancy exchange is
  24. I was able to up load still pics. But not animated pix. So you can still get different booty. Get it stuck with the same booty can be rough. Specialy when you see some better lookin booty
  25. Am I missing somthing here? or has yamaholic been drinkin to much Molson XXX
