wesw
Everything posted by wesw
  1. i think champ is referring a line that loco threw out when he didnt like his motor from jim.
  2. should be some number or letters on the top of your needle. that what you need to give to sudco. and 300 mains to start out with on your jetting. 270 will be lean most likely
  3. Ducman, its not just your cc's and timing you have to worry about, the squish clearance and squish band width must be matched to your cylinders at rated peak HP rpm in order for your squish velocity to fall into the right range. Re-cut off the shelf domes wont cut it...especially on hi-output designs on pump gas...Jim heres some advice. http://www.bansheehq.com/forums/index.php?showtopic=56778
  4. http://www.bansheehq.com/forums/index.php?showtopic=57037 look at the links at the bottom of rocketboy and i post
  5. http://news.yahoo.com/s/ap/20060222/ap_on_.../ports_security wow he is just the greatest leader. imo his own party doesnt like it
  6. might have to adjust some. best way is to do a plug chop.
  7. mine smoke more after it sits for a while like couple of weeks. could be the jetting and what type of oil you run. does it clear up?? does it do it every time??
  8. good seller. plan and simple
  9. have you put new plugs in and checked for spark.
  10. you need some bigger carbs if you have a drag port. but if you want to use the stockers. you need to go up on the pilot at least 27.5 maybe more. and raise the needle 5th clip. 390 main is big your probably need a different needle more thinner and shorter for more fuel. thats why your running that big of main. i woudl get some 30 + carbs imo if you want the full performance.
  11. you can get a plastic one for [email protected] email him tell him you heard about it on bansheehq and get free shipping. nice piece imo. was like 20 bucks
  12. should be able to leave the needle in the middle try some 230 mains with that elevation. might be rich still. plug chop
  13. try a 27.5 pilot, 4th clip on the needle, some 310 mains. and go from there it sounds like you fouled the plugs.
  14. you want the 2 arrows lined up when its free standing. not pulling on it. i push the little arm and some what get it lined up. then while still holding it, tighten the screw down to where the arrows are pretty close. then i adjust the free play on the lever.
  15. Is that what people refer to as a "suicide jockey"? please explain???
  16. jim at passions can get you a set.
  17. sorry there didnt need to get all pissy about it and yell
  18. drive a truck hauling asphalt oil in the summer and butane/propane thru out the yr.
  19. good pic the only thing i would have done was wash the motor off and the case so you dont get dirt and shit into it. but i guess you can clean it up when its all apart.
  20. ask 23champ and reded about a motor of kips on the dyno at waynoka.
  21. wesw
    a arm experts
    got some +2 arms from ebay. was wondering will the stock brake line fit still or will i need a new longer one. also do they make a boot or cover for those heim joint. dont think riding in the sand with them opened would be the best thing. want them to last and not wear out.
  22. what oil and what ratio is he running. you need to see what pilot he has my brother in law has what we call the misquito(spelling) killer. fucker leaves a fog behind it. ive told him i think his pilot is too big but hes one of those that know it all. fouls plus alot .
  23. 310-330 should be close i ran or used to run 340 but had vf reeds adn other stuff.
  24. to each their own. i dont think there is one special builder that builds the super bad ass motor for racing. sure there are many that do very well, but racing is more setup. you can have 110 hp, but if your setup doesnt get the power to the ground your pissing up a rope. my advice is do some searching and research. call them up and remember that everyone one you talk to will say they are the best. it comes down to more of a personal thing. does this guy sound like a prick or does he seem pretty cool. asking on here seems to turn into a pissing match. you probably get pm saying go here or there. but you have to do some checking on your own. IMO HAVE fun and get some vids of you racing.
  25. sounds like you leaned it out. you might put some 50 pilots in and see how it acts
