rebelbanshee2
Everything posted by rebelbanshee2
  1. you shift by rocking your foot instead of pivoting at your ankle. Harder to do when sitting since you can rock your body. take an aggressive knees bent stance and its perfect
  2. If im not mistaken the Fatty is the Gold series. They call them the Gold series Fatty
  3. have you tried new plugs?? a fouled plug can do that. Also do a leak down test, If you have a massive air leak it could be pulling enough air to totaly swamp it out
  4. notchy compared to a banshee?? is that even possible?
  5. if you have 22 in tires you may be better off with a 14t if they are 20in. then deffinately a 15
  6. to keep the nut from spinning take a steel and a fiber clutch plate and bolt them together. with this installed your clutch is locked together. now you can use a rag or penny between the gears to remove/install.
  7. very likely it is a bent tie rod. Its something you can do on your own, dont waste your money at a shop. Take the rod of and roll it on a flat surface to see if it is bent. if it is get a new one on ebay. In the end you will have in fixed for MANY times less than a dealer
  8. I agree with the local shop...can you describe where/what this is?
  9. I think of bump steer as when you wheels are going where your bars arnt pointing ie you have absolutely no controll over it. When you hit a bump your bars turn too...you *can* controll it with a damper and bigger arms....but i can see how getting the bars jerked could be considered bump steer
  10. I dont know why the shift shaft moves, but it does. the best was to keep this from happening is to make a spacer between the shifter and stator cover to keep it from slidding it.
  11. I bet the two smaller windows give more velocity/attomization than one larger window
  12. 19" was was about flush with the extended mag tube, we thought it would look altittle funny with a mag 1" longer than the barrel
  13. Its a fun little shotty. 870 with a +2 mag, top folding stock, and a home cut barrel to 19"...We call it Mr. Blasty
  14. Holyman is the one who got me onto this stuff. It shifts as smooth as ATF but lasts WAY longer. ATF looks like piss after one ride, this stuff I only change after 2-3 because I feel bad. $8 at walmart for 2 gallons. I run hard. Lots of power shifts, clutching every corner, and it puts up with it great
  15. I know honda, suzuki and kawasaki have the same patterns for the front and rear wheels. I know yamaha rear hubs are different than all of them. But, are Yamaha fronts the same as their fronts or are they different too?
  16. I hope you understabnd it is stil illegal to even assemble an AK. HAving just an AK receiver is considered an illegal assult rifle....if caught you wont get of like micheal jakson and OJ did....
  17. I know the rear pattern is different, but Im not sure about the fronts. Ive seen hipers that say for Yam, Hon Suz, but with only 1 set of holes. Are they the same?
  18. I was browsing and found this very interesting thread on LT setups. With all the talk about it on here I thought it would be relavent. CLICKY
  19. you are right. There is an "evil features list" for detachable mags guns. guns like mini14s, kel tecs have none of the features so they are good to go....for now You can only own "assult rifles" if they have been registered prior to the ban. Good thing we have the 2nd ammendment to protect our gun rights
  20. If you want a semi auto this is your only choice dudeFAB10
  21. A muzzle loader might be illegal under their new .50 ban..I dont know for sure though if it was just the BMG round Thats a tough one, but Im sure they would get you for "constructive intent" thats one of their favorite tricks I pray every day that California and NYC fall into the ocean.....someday..
  22. You absolutely cannot own an AK in Kalifornia. Any Semi-auto with a detachible mag is a big no-no!! Your only option for a semi-cool gun is a FAB-10 it basicaly and AR with a welded in 10rnd mag that you have to load with a stripper clip. Im not even sure you can legally look at pictures of guns while in california.
  23. BUMP everything that is listed is still available!
  24. looks like a absolutely horrible movie basing its entire success on big knockers
  25. tractor hydraulic transmission oil. Change after 2-3 rides
