like patching a hole in a case? i do know that gas will eat jb weld. its just epoxy with metel filler in it
There is not just one kind of jb weld only.0 Im pretty sure one kind is suited for what i want to do, thus why im asking.
Envoyé de mon SM-N975W en utilisant Tapatalk
Link to post
Claude, for most of my cold weld repairs I prefer the original 2 part JB weld. It works very very well for most applications. I only deviate from that kind in two situations.
1) If I need something more solid for a dry apication I use one part JB weld stick weld. Example, filling a hole in an engine block overhead. Often, standard JB weld will slowly drip out of the hole creating a crevice.
2) if I am in a hurry like at a ride and need to patch a hole in a case and get back to riding I use the JB weld 2 part kwik set. It works very well but not quite as good as the original.
Nothing beats the original if you have the time to let it cure.
  • Like 1
Link to post
In the jetski world, it is usually either original JB weld or Devcon aluminum Liquid for filling case voids, extending sealing area, or for case porting.  The original JB Weld thins and pours nicely when warmed and is typically cheaper.  Just be sure to overfill the area a little as there will be shrinkage as the epoxy cures.
Link to post
12 hours ago, ClaudeMachining said:
There is not one kind of jb weld. Im pretty sure one kind is suited for what i want to do, thus why im asking.
no there are multiples but the original works the "best" for this. but only works for a little while. if you have zero money in this sled then go for it.. but for patching a crank case id be tig welding it
Link to post
What do you mean it only works for a little while?
Sent from my SM-G975U using Tapatalk
Link to post
petroleum breaks down jb weld after time. turns it into a play dough like substance.
Link to post
