shakenbake1285 Posted August 20, 2008 Report Posted August 20, 2008 my shee backfires when u let off the throttle and will not idle at all. all stock, new plugs in it, just cleaned the carb and air filter does same thing Quote
shakenbake1285 Posted August 21, 2008 Author Report Posted August 21, 2008 help...................anyone Quote
shee4speed Posted August 21, 2008 Report Posted August 21, 2008 maybe your intake boots are leaking? Quote
shee4speed Posted August 21, 2008 Report Posted August 21, 2008 could be the spacing on the flywheel magnet thing.I cant remember the exact name. drawing a blank. Quote
shakenbake1285 Posted August 21, 2008 Author Report Posted August 21, 2008 (edited) is there an easy way to check the flywheel piece Edited August 21, 2008 by shakenbake1285 Quote
travis6767 Posted August 21, 2008 Report Posted August 21, 2008 ya all you need is a feeler gauge should be around .020'' between the pickup coil and the two tabs that set on the side of the flywheel Quote
