shakenbake1285
Everything posted by shakenbake1285
  1. Right now I have toomey t6 exhaust, uni air filter, and tors removed. I plan on getting trinity 2 into 1 carb. What are some other good mods?
  2. Right now I have toomey t6 exhaust, uni air filter, and tors removed. I plan on getting trinity 2 into 1 carb. What are some other good mods?
  3. What is the best or fastest way to get the rear bearings out
  4. Got it to idle fine. The little hose that connects the carbs came off (not the fuel lines)
  5. Carbs are alittle off need help on how to sync manually.
  6. How do I adjust the ping marks so the r centered at full throttle. Mine are alittle above the glass on the sides of the carbs
  7. When syncing carbs manually how to u adjust the ping marks in the glass in the side of the carbs. I know when the throttle is wide open the ping marks should b centered but I don't know how to move the ping marks.
  8. It's been awhile since I synced them how do I adjust the ping marks
  9. Ok thanks. I got the right carb tore apart to clean n c if that does anything
  10. My 05 banshee will not idle unless I choke it. I let it idle with choke on for few min then noticed my left exhaust was warm while my kick starter side was still cold. Any ideas how to fix or what is causing this.
  11. Do I have to buy new jets or can I adjust the stock ones n make them work ( if so what do I need to do)
  12. Yea I got all stock carbs. The bike will idle if I choke it. Is that from not being jetted (I tried the idle screws with no luck)
  13. Will idle if I choke it
  14. I got the pipes off a buddy he has jets n stuff on his bike
  15. And also who makes best jetkit and fastest place to get them delievered
  16. 1500 ft above sea level, toomey t6 exhaust, uni air filter and the tors r removed. Right now my bike will not idle and the bottom end has some miss in it n backfire is that because of stock jets n needles
  17. I just synced my carbs n now the bike walnt idle n when I ride it it has a hesitation on the bottom end. I have the tors removed
  18. What should I do or check to fix it
  19. I don't think I had the idle screws all the way in when I synced the carbs
  20. 100% posative tors r bypassed right
  21. I just got my carbs synced now I can't get it to idle. I took it for test ride n I noticed there was a miss in the bottom end. I have the tors removed
