LS1Inferno Posted September 15, 2008 Report Posted September 15, 2008 Thanks, I'll check that out. There also seams to be less smoke and air coming out of the left pipe, would that give an indication to what side might have the air leak? yeah the air leak is on that side. Quote
banshee man Posted October 2, 2008 Author Report Posted October 2, 2008 hey guys, i worked on my shee all weekend and i still cant find the problem. i checked for leaks, and i changed my pilots from 50's to 32's and it runs even worse. the idle is very unstable and tends to run by itself. i dont know what to do. its all stock except k&n pods and cpi in frames.. Quote
maxtrax Posted October 2, 2008 Report Posted October 2, 2008 You could have a crank seal leak. That would be under the side cover and explain why you are not finding it. Quote
desertdeweller Posted October 3, 2008 Report Posted October 3, 2008 do you have the choke tube in between the carbs installed properly that would cause that. Quote
maxtrax Posted October 5, 2008 Report Posted October 5, 2008 Is there anything special about the choke tube between the carbs or would a piece of fuel line work? My chokes haven't worked for a while, but I used a piece of fuel line because it was missing. Quote
LS1Inferno Posted October 5, 2008 Report Posted October 5, 2008 Is there anything special about the choke tube between the carbs or would a piece of fuel line work? My chokes haven't worked for a while, but I used a piece of fuel line because it was missing. nope its just a tube fuel line works fine. Quote
maxtrax Posted October 6, 2008 Report Posted October 6, 2008 nope its just a tube fuel line works fine. The chokes on mine don't seem to work. Sometimes I have to blow in one of the vent tubes to get it to prime in order to start. Would that be a problem with the chokes or the pilot not being big enough. Can the chokes even go bad? Quote
